Home » Modeling » Epsilon » links created with EWL is not appearing in diagram
links created with EWL is not appearing in diagram [message #638136] Wed, 10 November 2010 01:51 Go to next message
Abhijit Gurav is currently offline Abhijit Gurav
I created normal GMF project with some nodes and connecting link.
But now I want to insert nodes and connect them through wizard (EWL).
I have created .ewl file in which I have written code for the same i.e. creating new node and connect it with existing node through link.
e.g.
say in diagram i have like node A connecting to node B with link
A -----> B
I clicked on link and through wizards i entered new node C in between A and B. which will looks as follows,
A----->C------>B
Nodes are coming properly but connecting links are not coming on diagram, although its showing in node C and B as inputLink in property view.
But when I refreshed manually (F5), links appears ( I don't want user should do this.) . But they are not remain as it is. i.e When I closed diagram and opened it again they are gone. Sad
Anybody having any idea about the same. Please do reply.
NOTE : all the above stuff I am doing inside a compartment. (is that making mess. I don't know )
-AG
[Updated on: Wed, 10 November 2010 01:56]
Report message to a moderator
Re: links created with EWL is not appearing in diagram [message #638170 is a reply to message #638136] Wed, 10 November 2010 04:53 Go to previous messageGo to next message
Louis Rose is currently offline Louis Rose
Hi AG,
I've seen this issue before, but haven't quite figured out the root cause. A workaround is to force GMF to refresh the contents of the compartment.
Assuming a simple Statemachine metamodel, the following operation should suffice. (The states reference is the compartment).
operation forceRefresh() {
	var s : new State;
	Statemachine.all.first.states.add(s);
	delete s;
Then add a call to the operation at the end of the do part of the EWL wizard:
do {
	// The rest of the do block...
	forceRefresh();
Hope this helps.
Louis.
Re: links created with EWL is not appearing in diagram [message #638255 is a reply to message #638136] Wed, 10 November 2010 08:10 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
I've had a chat about this with Louis offline and he said he has a
workaround for this so I guess he'll get back to you on this shortly.
Dimitris
On 10/11/2010 06:51, abhijit.gurav@atosorigin.com wrote:
> But now I want to insert nodes and connect them through wizard (EWL). I
> e.g.
> say in diagram i have like node A connecting to node B with link L1
> L1
> A -----> B
> I clicked on L1 and through wizards i entered new node C in between A
> and B. which will split the link in two as follows,
> L1 L2
> A----->C------>B
> view.
> diagram and opened it again they are gone. :(
> -AG
Re: links created with EWL is not appearing in diagram [message #639595 is a reply to message #638255] Wed, 17 November 2010 01:15 Go to previous message
Hi Louis and Dimitris,
Thanks for reply, I will definitely try your approach. But meanwhile I succeed to refresh the edtior diagram by using adator notification which also solved my issue.
Once again Thanks for help.
-AG
Previous Topic:HutnGenerationException in property of an element
Next Topic:[EWL] Customizing Wizard menu name and position in context menu
Current Time: Wed Jun 19 07:45:55 EDT 2013
Powered by FUDForum. Page generated in 0.01693 seconds
