Home » Language IDEs » Java Development Tools (JDT) » eclipse memory setting
eclipse memory setting [message #638093] Tue, 09 November 2010 21:33 Go to next message
fachhoch Mising name is currently offline fachhoch Mising nameFriend
here is my eclipse .ini file I set the memory arguments but its not working please tell me whats wrong
#This configuration file was written by: org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxFwConfigFileParser
#Wed Oct 13 13:13:45 EDT 2010
org.eclipse.update.reconcile=false
eclipse.p2.profile=epp.package.jee
osgi.instance.area.default=@user.home/workspace
osgi.framework=file\:plugins/org.eclipse.osgi_3.5.1.R35x_v20090827.jar
eclipse.buildId=M20090917-0800
osgi.bundles=reference\:file\:org.eclipse.equinox.simpleconfigurator_1.0.101.R35x_v20090807-1100.jar@1\:start
org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.eclipse.equinox.simpleconfigurator/bundles.info
eclipse.product=org.eclipse.platform.ide
osgi.splashPath=platform\:/base/plugins/org.eclipse.platform
osgi.framework.extensions=reference\:file\:org.eclipse.equinox.weaving.hook_1.0.0.200905261348.jar,reference\:file\:javax.transaction_1.1.1.v201002111330.jar,reference\:file\:org.eclipse.persistence.jpa.equinox.weaving_1.1.3.v20091002-r5404.jar
osgi.bundles.defaultStartLevel=4
eclipse.p2.data.area=@config.dir/../p2/
eclipse.application=org.eclipse.ui.ide.workbench
-vmargs
-Xms128m
-Xmx1024m
-XX:PermSize=256m
are my settings write ?
Re: eclipse memory setting [message #638098 is a reply to message #638093] Tue, 09 November 2010 21:42 Go to previous message
Originally posted by: richkulp.us.NOSPAM.ibm.com
That's not a valid ini file. That is combination of
confinguration/config.ini file and the eclipse.ini file. They shouldn't
be combined.
The following kind of stuff belongs in the configuration/config.ini file:
org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxF wConfigFileParser
osgi.framework=file\:plugins/org.eclipse.osgi_3.5.1.R35x_v20 090827.jar
osgi.bundles=reference\:file\: org.eclipse.equinox.simpleconfigurator_1.0.101.R35x_v2009080 7-1100.jar @1\:start
org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.e clipse.equinox.simpleconfigurator/bundles.info
The stuff you wanted belongs in the eclipse.ini file:
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Dosgi.bundlefile.limit=100
-Xms100m
-Xmx512m
So you need to first get a valid eclipse.ini file before you can modify it.
Rich Kulp
Previous Topic:SourceFile attribute wrong when compiling with eclipse batch compiler
Next Topic:Code Snap in Editor Window
Current Time: Mon May 28 10:05:02 GMT 2018
Powered by FUDForum. Page generated in 0.01797 seconds
