Home » Eclipse Projects » BIRT » Cant create data engine. (installed all-in-one birt eclipse)
Cant create data engine. [message #638037] Tue, 09 November 2010 12:36 Go to next message
James Mising name is currently offline James Mising name
I just installed the latest birt all in one 2.6 and have it up and running smooth. However, I am trying to build a chart and when I insert a chart into the workspace, it gives me this error:
org.eclipse.birt.chart.exception.ChartException at:
org.eclipse.birt.chart.reportitem.ui.ReportDataServiceProvid er.initialize(ReportDataServiceProvider.java:279)
org.eclipse.birt.chart.ui.swt.wizard.preview.ChartLivePrevie wThread.initDataEngine(ChartLivePreviewThread.java:237)
org.eclipse.birt.chart.ui.swt.wizard.preview.ChartLivePrevie wThread.run(ChartLivePreviewThread.java:153)
Caused By:Loader can not resolve Rhino classes
org.mozilla.javascript.Context.setApplicationClassLoader(Con text.java:2306)
org.eclipse.birt.report.engine.javascript.JavascriptEngine.s etApplicationClassLoader(JavascriptEngine.java:325)
org.eclipse.birt.core.script.ScriptContext.createEngine(Scri ptContext.java:244)
org.eclipse.birt.core.script.ScriptContext.getScriptEngine(S criptContext.java:230)
org.eclipse.birt.report.engine.adapter.ModelDteApiAdapter.<init >(ModelDteApiAdapter.java:177)
org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.<init >(AbstractDataEngine.java:107)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.<init >(DteDataEngine.java:85)
org.eclipse.birt.report.engine.data.DataEngineFactory.create DataEngine(DataEngineFactory.java:100)
org.eclipse.birt.report.engine.executor.ExecutionContext.ope nDataEngine(ExecutionContext.java:837)
org.eclipse.birt.report.engine.executor.ExecutionContext.get DataEngine(ExecutionContext.java:854)
org.eclipse.birt.report.engine.api.impl.EngineTask.getDataSe ssion(EngineTask.java:525)
org.eclipse.birt.chart.reportitem.ui.ReportDataServiceProvid er.initialize(ReportDataServiceProvider.java:257)
I have re-installed in several times but no luck, I really need this chart tool .
Re: Cant create data engine. [message #638039 is a reply to message #638037] Tue, 09 November 2010 12:45 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
James,
Can you give some more detail? Are you installing it in a new location
or overwriting an existing location. Did you use the 2.6. or the 2.6.1
allinone download?
Jason
> text.java:2306)
> ptContext.java:244)
> chart tool .
> Thanks
Jason Weathersby
BIRT Exchange
Re: Cant create data engine. [message #638040 is a reply to message #638039] Tue, 09 November 2010 12:50 Go to previous messageGo to next message
Hi Jason,
thanks for getting back so quick. I downloaded 2.6.1 all-in-one about an hour ago from http://www.eclipse.org/birt/phoenix/ in a new location (new folder on my windows desktop). I also have another older version installed elsewhere on my computer.
[Updated on: Tue, 09 November 2010 12:54]
Report message to a moderator
Re: Cant create data engine. [message #638046 is a reply to message #638040] Tue, 09 November 2010 12:51 Go to previous messageGo to next message
What Java Vm are you using?
Can you try unzipping in a directory off the c drive eg
c:/birt/2.6.1allinone
Jason
On 11/9/2010 12:50 PM, James wrote:
> Hi Jason,
> thanks for getting back so quick. I downloaded 2.6.1 about an hour ago
Jason Weathersby
BIRT Exchange
Re: Cant create data engine. [message #638054 is a reply to message #638037] Tue, 09 November 2010 13:51 Go to previous messageGo to next message
Jason,
I extracted in a folder from C drive like you said. I tried something too, I created a new report project with a blank report file and tried it, and it worked, I was able to create a chart without that issue. However when I check out our project code from SVN is it then when I am noticing this issue. It never had this problem with older versions of BERT (2.4 and 2.5). Me and another guy are using different older versions of BERT to build reports and both work fine just have issues opening each others reports to edit them, so that is why we are trying to just upgrade to the latest and be compatible. Might it have to do with the location of where I am creating the report file? Our current reports live within a Package with other java files.
One more thing I tried and noticed too was that it worked when I tried to add a chart to a report file in a new report project, and didnt work when I tried to add a chart to a report file within our code checked out from SVN.
Thanks again for your help.
[Updated on: Tue, 09 November 2010 14:14]
Re: Cant create data engine. [message #638058 is a reply to message #638054] Tue, 09 November 2010 14:21 Go to previous messageGo to next message
I think I might have figured it out (or I got it to work). I created a report project (outside of our svn code) and copied our report files in there, I was the able to add and mess with charts. Let me know if you think that makes sense.
Thanks again for your help!
Re: Cant create data engine. [message #638062 is a reply to message #638058] Tue, 09 November 2010 14:44 Go to previous messageGo to next message
James,
I am not exactly sure what you mean. When you create report inside your
project it fails?
Jason
Jason Weathersby
BIRT Exchange
Re: Cant create data engine. [message #638065 is a reply to message #638062] Tue, 09 November 2010 14:53 Go to previous messageGo to next message
Please excuse my poor java/eclipse terminology. In eclipse, you can create different types of projects (Report Projects, Java projects, JPA projects , etc). Our project in eclipse is within a Java project which contains all of our code (including our report files). When trying to create or edit BIRT charts while within that project, it gives me the error "no data engine can be found" when I create a new report file or copy an existing one over within a separate "report project" it works fine. Does that make sense?
Re: Cant create data engine. [message #638072 is a reply to message #638065] Tue, 09 November 2010 15:29 Go to previous messageGo to next message
James
Understood. Does you project have any dependencies set that reference
birt projects? Also does your report call any java classes?
Jason
Jason Weathersby
BIRT Exchange
Re: Cant create data engine. [message #638074 is a reply to message #638072] Tue, 09 November 2010 15:40 Go to previous messageGo to next message
Jason,
I don't know if there are dependencies set that reference birt projects, I will look though. My reports don't call java classes. Thanks again for your help! Razz
Re: Cant create data engine. [message #639888 is a reply to message #638074] Thu, 18 November 2010 04:39 Go to previous messageGo to next message
yymer  is currently offline yymer
I had the same problem.
The problem for me was that my java-project contained old birt-libraries.
Replacing them with the new ones solved it.
You might want to inform the people responsible for the java-project that
you will be using an updated version of birt, and that they might have to do the same.
Have a nice day!
Re: Cant create data engine. [message #640503 is a reply to message #638037] Mon, 22 November 2010 06:35 Go to previous messageGo to next message
Lionel is currently offline Lionel
Member
James avait énoncé :
I have the same problem.
I have installed the latest helios release and downloaded the lastest
report engine release (2.6.1).
When I copy the jars of the report engine inside my tomcat/lib's
folder, eclipse crashes this error when I edit a chart.
If I remove the jars, everything works, but of course once deployed I
can't generate charts and my project doesn't compile anymore.
Is there an incompatibility between eclipse's jars and report engine's
jars ?
Which report engine should I use ?
thanks for your help.
Re: Cant create data engine. [message #640651 is a reply to message #640503] Mon, 22 November 2010 11:53 Go to previous messageGo to next message
Can you give some more detail on how you are using the engine?
If you are using BIRT in an RCP application there is no need to download
the runtime. If you are deploying BIRT to an app server you will need
the runtime.
Jason
> Hello,
> When I copy the jars of the report engine inside my tomcat/lib's folder,
> jars ?
Jason Weathersby
BIRT Exchange
Re: Cant create data engine. [message #640664 is a reply to message #640651] Mon, 22 November 2010 12:56 Go to previous messageGo to next message
Member
Jason Weathersby a formulé ce lundi :
> If you are using BIRT in an RCP application there is no need to download the
> runtime. If you are deploying BIRT to an app server you will need the
> runtime.
Hello Jason,
I run the engine inside a webapplication which runs on tomcat.
I include the report engine libs inside tomcat/lib folder because I
need them to start the engine (using BirtEngine.java as in the
documentation).
As they are in tomcat, my webproject see them in the build path, they
seem to override eclipse's jars.
Re: Cant create data engine. [message #640673 is a reply to message #640664] Mon, 22 November 2010 13:39 Go to previous messageGo to next message
Understood. Can you try to leave all the libs and create a separate
report project in the same workspace to create and modify your reports.
Jason
>> download the runtime. If you are deploying BIRT to an app server you
>> will need the runtime.
> Hello Jason,
> I include the report engine libs inside tomcat/lib folder because I need
> them to start the engine (using BirtEngine.java as in the documentation).
Jason Weathersby
BIRT Exchange
Re: Cant create data engine. [message #642237 is a reply to message #640673] Tue, 30 November 2010 08:51 Go to previous messageGo to next message
Member
Jason Weathersby a exposé le 22/11/2010 :
> Understood. Can you try to leave all the libs and create a separate report
This won't work, I need to run my reports from my application.
I can't use the preview because I use scripted dataset filled with
POJOs loaded by my application (writing complex SQL statements with
dynamic criterions/joins inside BIRT is not manageable).
I have to edit the reports inside my webpp project.
Is there some jars I could overwrite in eclipse plugins folder to make
it work ?
Re: Cant create data engine. [message #642262 is a reply to message #642237] Tue, 30 November 2010 11:01 Go to previous messageGo to next message
Lionel,
It would be good if you could log a bug for this.
If you create a separate report project you should be able to set its
classpath to the jars in your Java project in the preferences.
Jason
> I can't use the preview because I use scripted dataset filled with POJOs
> loaded by my application (writing complex SQL statements with dynamic
> it work ?
Jason Weathersby
BIRT Exchange
Re: Cant create data engine. [message #642273 is a reply to message #638037] Tue, 30 November 2010 11:25 Go to previous messageGo to next message
Loebe is currently offline Loebe
Exactly the same problem here. As soon as i include the BIRT runtime jars to the webapp lib directory, the same exception appears on inserting a new chart to a report. I tried a lot of constelations of build path. But no luck so far.
I think creating a new report project would be a possible workaround. But its not that pretty...
Hope for a fix or a hint soon. I'll post back if i could figure it out by myself.
Best regards!
Re: Cant create data engine. [message #642280 is a reply to message #642273] Tue, 30 November 2010 11:36 Go to previous messageGo to next message
I do not think there has been a bug logged for this yet.
Jason
> build path. But no luck so far. I think creating a new report project
> by myself.
> Best regards!
Jason Weathersby
BIRT Exchange
Re: Cant create data engine. [message #642394 is a reply to message #642280] Wed, 01 December 2010 02:53 Go to previous messageGo to next message
done.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=331504
[Updated on: Wed, 01 December 2010 02:57]
Re: Cant create data engine. [message #642569 is a reply to message #642394] Wed, 01 December 2010 14:18 Go to previous messageGo to next message
Thanks. Can you post the bug number?
Jason
On 12/1/2010 2:53 AM, loebe0@gmail.com wrote:
> Quote:
> done.
Jason Weathersby
BIRT Exchange
Re: Cant create data engine. [message #642584 is a reply to message #642394] Wed, 01 December 2010 16:00 Go to previous messageGo to next message
Loebe wrote on Wed, 01 December 2010 02:53
done.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=331504 <------- NUMBER
Re: Cant create data engine. [message #727174 is a reply to message #638037] Tue, 20 September 2011 11:05 Go to previous message
Kees Pieters is currently offline Kees Pieters
I had this problem myself, and the reason was that I had not added all the birt reporting plugins. Apparently a number of plugins add functionality through the extension mechanism, and so when you do not add these plugins, some tasks may fail.
In my particular case, the engine needed the javascript scripting plugin.
Previous Topic:Need help with XML Data source parametrized report
Next Topic:Can a BIRT report generated from within JBOSS be sent as email
Current Time: Fri May 24 23:12:39 EDT 2013
Powered by FUDForum. Page generated in 0.03110 seconds
