Home » Modeling » VIATRA » Concrete models and VTCL transformations(How VTCL Transformations reference the meta model instances?)
Concrete models and VTCL transformations [message #638004] Tue, 09 November 2010 15:48 Go to next message
annie 84 is currently offline annie 84Friend
Hello:
I am a beginner and trying to implement simple transformations to learn the VIATRA framework. I executed all the beginner's transformation tutorials successfully but now I am stuck in Activitytopetrinet transformation case study. The structure of the project and the files available in the project folder are quite understandable. However, I can not understand how the transformations written in VTCL files reference the input activity diagrams? In the UML folder in this example there are three activity models, activity_prb, activity_complex and activity_forkjoin. The transformation instance in the program model is referring which of these activities is really un-understandable for me.
In the VPML structure as well, I can see the meta-models but there is nothing about the model instances. When I execute this transformation, I simply get a message "Transformation Terminated". Can anyone help?
Quratulann
Re: Concrete models and VTCL transformations [message #638035 is a reply to message #638004] Tue, 09 November 2010 17:20 Go to previous message
Zoltan Ujhelyi is currently offline Zoltan UjhelyiFriend
The VPM model space does not contain the required instance models, as you have already seen.
Before you can run the transformation, you have to use the UML importer (see the following wiki page for more details: http://wiki.eclipse.org/VIATRA2/GettingStarted/Using_Transfo rmations - it describes how to run this simple transformation).
The transformation description wiki page has been updated to emphasize this link.
[Updated on: Tue, 09 November 2010 17:23] by Moderator
Report message to a moderator
Previous Topic:Import UML model
Next Topic:Please criticise my transformation
Current Time: Mon Jun 18 00:30:14 GMT 2018
Powered by FUDForum. Page generated in 0.02514 seconds
