Home » Modeling » EMF » [CDO] Connection aware URIs
[CDO] Connection aware URIs [message #637142] Thu, 04 November 2010 10:59 Go to next message
Alex Lagarde is currently offline Alex LagardeFriend
Hy everyone,
I was wondering if there is any mechanism in CDO to persist repository locations ?
I explain myself : if I reference in a local xmi resource a CDOResource, the URI will be persisted : "cdo://repo1/myResource.xmi". There is no problem with that while I'm connected to the CDO Repository (repo1) containing the resource, as CDOURIHandlers will retrieve this Resource.
Let's now say that I have closed my connection and my local Resource. When I re-open this local Resource, CDOURIHandlers aren't able to retrieve the referenced CDOResource any more, as the connection to the repository has been closed.
Is there any mechanism that would allow me to connect automatically to the Repository location corresponding to its UUID ("repo1") ?
If not, do you think that creating my own URIHandler,capable of dealing with URI such as "cdo://repo1/myResource.xmi##tcp://localhost:2036" by connecting to the Repository if no connection is detected, is a good idea ?
Thanks !
Re: [CDO] Connection aware URIs [message #637151 is a reply to message #637142] Thu, 04 November 2010 11:50 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 04.11.2010 11:59, schrieb alagarde:
> Hy everyone,
A very good idea (except for the hash signs in your example)! That's why I implemented it just the other week :P
Please have a look at:
291574: Provide connection-aware URI formats
https://bugs.eclipse.org/bugs/show_bug.cgi?id=291574
Cheers
/Eike
http://www.esc-net.de
> Thanks !
Re: [CDO] Connection aware URIs [message #637152 is a reply to message #637151] Thu, 04 November 2010 11:52 Go to previous messageGo to next message
Correction, it is this bugzilla:
326186: Provide a URI format that contains connection information
https://bugs.eclipse.org/bugs/show_bug.cgi?id=326186
Cheers
/Eike
Am 04.11.2010 12:50, schrieb Eike Stepper:
>> Hy everyone,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Thanks !
Re: [CDO] Connection aware URIs [message #637169 is a reply to message #637152] Thu, 04 November 2010 12:58 Go to previous messageGo to next message
Thanks a lot for you fast reply, as usual !
I'm going to use it right now.
Re: [CDO] Connection aware URIs [message #637227 is a reply to message #637169] Thu, 04 November 2010 16:30 Go to previous messageGo to next message
Hy again !
I have tested the Connection-aware URIs and they are perfect for my useCase.
However, I would like to activate these URIs by default, so that if I reference a CDOObject from a local Resource the href serialized is a connection-aware URI and not a standard CDO URI.
I don't know if I'm clear : I would like my xmi file to look like :
 <referencedElement xmi:type="cars:Garage" href="cdo.net4j.tcp://localhost/repo1/remoteSemanticResource.xmi?transactional=true#1"/>
and not
<referencedElement xmi:type="cars:Garage" href="cdo:t/repo1/remoteSemanticResource.xmi#1"
I've tried to use the code from ViewProviderTest for getting the CDOResource :
final URI resourceURI = new CDONet4jViewProvider.TCP().getResourceURI(transaction, remoteResourcePath);
ResourceSet resourceSet = new ResourceSetImpl();
 final CDOResource remoteResource = (CDOResource) resourceSet.getResource(resourceURI, true);
but when my local resource is saved I still have a simple CDO URI. I also tried to set ruffly the Connection-aware URI to my resource but this don't work either.
Am I missing something here ?
Re: [CDO] Connection aware URIs [message #637399 is a reply to message #637227] Fri, 05 November 2010 11:02 Go to previous messageGo to next message
Am 04.11.2010 17:30, schrieb alagarde:
> Hy again !
> <referencedElement xmi:type="cars:Garage" href=" cdo.net4j.tcp://localhost/repo1/remoteSemanticResource.xmi?t ransactional=true#1"/>
> and not
Not necessarily. This feature has been developed with some very specific use cases in mind, and tested for these. It's well possible that this whole brand new feature does not yet fulfil any possible requirement. Can you please reopen the bugzilla and add a comment so that it reminds me to validate your use case?
Cheers
/Eike
Re: [CDO] Connection aware URIs [message #637935 is a reply to message #637399] Tue, 09 November 2010 12:07 Go to previous messageGo to next message
posted a comment on the bugzilla (https://bugs.eclipse.org/bugs/show_bug.cgi?id=326186) but cannot re-open the bug (only the bug creator can, am I right ?).
Re: [CDO] Connection aware URIs [message #637940 is a reply to message #637935] Tue, 09 November 2010 12:12 Go to previous messageGo to next message
Am 09.11.2010 13:07, schrieb alagarde:
That's what we've also figured. Please just open a new one if you think it's adequate ;-)
Cheers
/Eike
Re: [CDO] Connection aware URIs [message #637942 is a reply to message #637940] Tue, 09 November 2010 12:27 Go to previous messageGo to next message
Hy,
I don't think that created a new bug is the best idea, as my feature request is clearly in the bug scope.
Thanks again for your interest !
Re: [CDO] Connection aware URIs [message #637965 is a reply to message #637942] Tue, 09 November 2010 13:31 Go to previous messageGo to next message
Am 09.11.2010 13:27, schrieb alagarde:
> Hy,
The bugzilla that you can not reopen was to track the effort for a paying customer. Your requirements are not included in his requirements. Please open a new bugzilla.
Cheers
/Eike
Re: [CDO] Connection aware URIs [message #637973 is a reply to message #637965] Tue, 09 November 2010 14:03 Go to previous message
That's done : https://bugs.eclipse.org/bugs/show_bug.cgi?id=329786.
Thanks again, for now on I've made a nice work around to ensure proper reconnection.
As I said in the bugzilla, it would be great to have enough extensibility to control how the reconnection processes (how to create the session/the transaction ? When closing it ?).
Previous Topic:Configuration for Tables
Next Topic:Ecore Model
Current Time: Thu May 24 17:38:21 GMT 2018
Powered by FUDForum. Page generated in 0.01910 seconds
