Home » Eclipse Projects » Eclipse Platform » Maven Error assembling WAR
Maven Error assembling WAR [message #637046] Wed, 03 November 2010 22:49 Go to next message
john  is currently offline john Friend
i got the follwoign error when i tried i run the following command line:-
>>mvn clean install
[INFO] Error assembling WAR: webxml attribute is required (or pre-existing WEB-I
NF/web.xml if executing in update mode)
so i have maually created the web.xml file on the required directory, and i rerun the command line again and every thig went succsfully.
So did i do the right thing?
and how i can let the maven it self to create the web.xml file?
Re: Maven Error assembling WAR [message #641252 is a reply to message #637046] Wed, 24 November 2010 16:18 Go to previous message
szymon is currently offline szymonFriend
from here
This problem is solved by this way -- just add to your pom.xml following plugin with the WebXml attribute (here u should set path to your web.xml):
<  build  >
  < plugins  >
  < plugin  >
  < groupId  >org.apache.maven.plugins<  /groupId  >
  < artifactId  >maven-war-plugin<  /artifactId
  < configuration  >
  < webXml  >WebContent/WEB-INF/web.xml<  /webXml >
  < /configuration  >
  < /plugin  >
  < /plugins  >
  < finalName  >u-app<  /finalName  >
 < /build  >
Previous Topic:Content Assist displayed as tree in separate view
Next Topic:Reading Command Line Parameters in RCP App
Current Time: Sun May 27 12:09:56 GMT 2018
Powered by FUDForum. Page generated in 0.01728 seconds
