Home » Newcomers » Newcomers » RCP application : change workspace location @ RT
RCP application : change workspace location @ RT [message #636910] Wed, 03 November 2010 06:17 Go to next message
eclipsed  is currently offline eclipsed
Hi all
How to change your rcp application workspace location at run time.
in IWorkspaceRoot there is no setlocation or some thing similar.
can some one gives me a solution or a hint.
Re: RCP application : change workspace location @ RT [message #638081 is a reply to message #636910] Tue, 09 November 2010 15:56 Go to previous message
Eric Rizzo is currently offline Eric Rizzo
On 11/3/10 6:17 AM, eclipsed wrote:
> Hi all
You can use the Plug-in Menu Spy feature (Shift+Alt+F2) and then point
at any menu item to see the plugin name that contributes that menu item.
From there you can go find the source code and see how it is
accomplishing its task.
For your case, there is the File > Switch Workspace menu that seems
relevant.
It's plugin info is
The active contribution item class:
OpenWorkspaceAction$OpenDialogAction
The contributing plug-in:
org.eclipse.ui.ide (3.6.0.I20100601-0800)
Eric
Previous Topic:Looks like I have a lot to learn
Next Topic:Importing EMFatic into an EMF project
Current Time: Sat May 25 02:19:23 EDT 2013
Powered by FUDForum. Page generated in 0.03150 seconds
