Home » Modeling » Papyrus » Model validation(No model validation menu in Papyrus as a plug-in)
Model validation [message #636577] Tue, 02 November 2010 01:39 Go to next message
Yannick Duchene (Hibou57) is currently offline Yannick Duchene (Hibou57)Friend
Member
Hi all,
The Papyrus plug-in for UML, has no validation feature at all. I've just noticed the RCP version has a bit of that : in Papyrus RCP, you can right-click on the model outline view, and get a "Validate Model" menu entry. Not a validation during edition, but that is still better than no validation at all.
It is not there with the plug-in version of Papyrus ? What makes it possible with the RCP version (which I will not use because it come with other problems) and not with the plug-in version ?
I feel an UML editor is useless without validation. I wanted to access Papyrus sources to see if there is a way to add this capability to Papyrus but I could not access the sources, because the SVN repository seems broken (see http://www.eclipse.org/forums/index.php?t=msg&th=199504 about that topic).
That is not easy to get a good UML editor : ArgoUML is validating editor, but does not know at all about UML-DI (which is the standard for diagrams), TopCased is validating and know UML-DI, but has failures at runtime and when importing XMI, Papyrus can save XMI and UML-DI (while does cannot populate a diagram from these), but is not validating. No need to talk about all the other editors, which are just picture-drawing applications (no one should call these "UML editor")
There is always something wrong Sad
P.S. SVG export could also be a requirement, however, validation is really the first requirement of all (with support for standards, XMI and UML-DI, for interoperability).
Re: Model validation [message #636889 is a reply to message #636577] Wed, 03 November 2010 09:11 Go to previous message
Patrick Tessier is currently offline Patrick TessierFriend
We are working on the validation Very Happy So I think il will be available in few weeks in the nightly build. you can see in the bugzilla that a task has been added.
For the requirement about export with SVG. have you look for if the taks exists in hte bugzilla?
Previous Topic:"Repository moved permanently ..."
Next Topic:Modify palette at runtime
Current Time: Sat Jan 20 19:15:51 GMT 2018
Powered by FUDForum. Page generated in 0.02079 seconds
