Home » Eclipse Projects » Remote Application Platform (RAP) » JAAS login module in a Jar
JAAS login module in a Jar [message #636097] Fri, 29 October 2010 09:44 Go to next message
Opfermann C is currently offline Opfermann CFriend
Member
I'm trying to activate the equinox security with a login screen in my RAP application.
I already have a login module which I have to use and which is located in an imported JAR.
When I export the application to a WAR file and I test it under Tomcat, I need to add my login module jar in the lib folder of Tomcat which is very strange because I already have it imported in my plugin.
When I test it in Eclipse by lauching the RAP application, I can't get it work because I get a classnotfound exception on my login module class (which is imported as jar in my plugin).
Has somebody already found a solution on how the login module jar can be used in a plugin ?
Re: JAAS login module in a Jar [message #636562 is a reply to message #636097] Mon, 01 November 2010 21:37 Go to previous messageGo to next message
Originally posted by: djlynott.rockwellcollins.com
On 10/29/2010 4:44 AM, Opfermann C wrote:
> RAP application.
> in an imported JAR.
> used in a plugin ?
I'm not entirely sure how your project is composed, but I ended up
having to create my login modules as fragments for the classloader
within the primary authentication plugin to resolve the classes.
Although I'm simplifying things a bit, I essentially had the following:
- authorization bundle/plug-in that performed the JAAS
LoginContext.login() method
- login module strategies composed as fragments to reduce coupling,
allow equinox bind them to the parent plug-in if available in the
install and be visible to the classloader of the authorization bundle
This seemed messy but it allowed me share a login dialog based on
Eclipse SWT between RAP and RCP installations. Despite working through
the classloader issues, I did eventually discover that creating a dialog
within a LoginModule would prevent interaction with the RAP application
by a given person using multiple browser instances until the login phase
succeeded. To get around this, within a RAP execution context, I present
the dialog then pass the credentials along to JAAS vs. have JAAS open
the dialog internally.
Did that make any sense?
-- Dave
Re: JAAS login module in a Jar [message #636609 is a reply to message #636562] Tue, 02 November 2010 08:02 Go to previous messageGo to next message
Member
Hi Dave,
Thanks for your answer.
Yes, this makes sense for me too that separating the JAAS into a fragment can avoid classloader issue.
But for the second part, I can't really understand why you make the dialog call JAAS instead of opening the login dialog inside JAAS.
I'll try to separate the LoginModule to a fragment to see what happends...
Re: JAAS login module in a Jar [message #636678 is a reply to message #636609] Tue, 02 November 2010 12:59 Go to previous message
Originally posted by: dave.lynott.yahoo.com
I didn't really want to call the dialog outside of the JAAS framework.
Unfortunately, I had to under RAP since I was seeing that weird
deadlock-like issue. If you do something similar and don't have that
issue, let me know how you accomplished it.
BTW: Calling it from within JAAS under an RCP application worked fine
for me. Under RAP, it would open, I just couldn't log in from other
browser instances while the dialog was showing. I can't remember now if
it was limited to the user with the dialog showing or all users
attempting to log in. I do know I really didn't notice the problem till
I deployed it (probably because I'm in debug most of the time and not
trying to create multiple instances of the application in other browser
windows).
-- Dave
Previous Topic:RAP Startup Page
Next Topic:Electronic signature
Current Time: Fri Feb 23 18:49:28 GMT 2018
Powered by FUDForum. Page generated in 0.02032 seconds
