Re: Change an image properties before the report generation [message #635691 is a reply to message #635451] |
Wed, 27 October 2010 17:51   |
Yes this is possible. You can also change it in script.
In Java like this:
ReportDesignHandle report = (ReportDesignHandle) design.getDesignHandle( );
ImageHandle myimage =(ImageHandle)report.findElement("MyImage1");
myimage.setURL("\"http://tomcat.apache.org/images/tomcat.gif\"");
In the above example note that the image element has been named in the
general properties for the image.
in Script
//beforeFactory script
var img1 =reportContext.getDesignHandle().findElement("MyImage1");
img1.setURL("\"http://tomcat.apache.org/images/tomcat.gif\"");
Jason
On 10/26/2010 4:25 PM, FrenchGuy wrote:
> I am generating a report using Report Engine classes and I would like to
> change the url of an image inserted in the report using BIRT Report
> Designer.
> Is it possible to access this item and change its properties before the
> generation?
> this is a sample of my code :
> IReportEngine engine = null;
> engine = Engine.getInstance().getEngine();
> IReportRunnable design = null;
> // Open the report design
> try {
> design = engine.openReportDesign(report.getSource());
> } catch (EngineException e) {
> LoggerBI.getInstance().fatal("", e);
> return false;
> IRunAndRenderTask runtask = engine.createRunAndRenderTask(design);
> ULocale lc = new ULocale(task.getLocale());
> runtask.setLocale(lc);
> runtask.setParameterValues(reportParams);
> try {
> runtask.run();
> LoggerBI.getInstance().error("", e);
> return (false);
> runtask.close();
> Thanks!
FUDForum. Page generated in 0.02317 seconds
