Home » Modeling » GMF (Graphical Modeling Framework) » how to save model file using xmi?
how to save model file using xmi? [message #635306] Tue, 26 October 2010 11:08 Go to next message
popjxc is currently offline popjxcFriend
Member
Hi all,
I use gmf generate a editor, and save graphics and model in two different files.
in my model file, it use xsi like the following:
<model:Diagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:model="http://model/1.0" name="Diagram">
  <transitions from="_tsqBwODtEd-r576wsnzzcA" to="_t1tQEODtEd-r576wsnzzcA" id="_uHgxwODtEd-r576wsnzzcA" type="transition"/>
  <nodes xsi:type="model:SQL" name="SQL" targets="_uHgxwODtEd-r576wsnzzcA" id="_tsqBwODtEd-r576wsnzzcA"/>
  <nodes xsi:type="model:File" name="File" sources="_uHgxwODtEd-r576wsnzzcA" id="_t1tQEODtEd-r576wsnzzcA"/>
</model:Diagram>
But I saw the saved file of the eclipse bpmn, in the model file it use xmi, like the following:
<bpmn:BpmnDiagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:bpmn="http://stp.eclipse.org/bpmn" xmi:id="_6m9gIdK3Ed-akOyjfwNYew" iD="_6m9gINK3Ed-akOyjfwNYew">
  <artifacts xmi:type="bpmn:DataObject" xmi:id="_Rsf9UdTyEd-W5N3rDCZOsQ" iD="_Rsf9UNTyEd-W5N3rDCZOsQ">
    <associations xmi:type="bpmn:Association" xmi:id="_RtifINTyEd-W5N3rDCZOsQ"/>
  </artifacts>
  <pools xmi:type="bpmn:Pool" xmi:id="_6nQbEdK3Ed-akOyjfwNYew" iD="_6nQbENK3Ed-akOyjfwNYew" associations="_RtifINTyEd-W5N3rDCZOsQ" name="Pool">
    <vertices xmi:type="bpmn:Activity" xmi:id="_6clugeDhEd-Q7Yw7T3vQ_w" iD="_6clugODhEd-Q7Yw7T3vQ_w" activityType="Task" looping="true"/>
  </pools>
</bpmn:BpmnDiagram>
So, how can I change my 'xsi:type' to 'xmi:type', and add 'xmi:id' ?
Thanks very much!
Re: how to save model file using xmi? [message #635400 is a reply to message #635306] Tue, 26 October 2010 15:44 Go to previous messageGo to next message
Be sure to use a resource factory that created XMIResourceImpl instances
for serializing and deserializing your model.
popjxc wrote:
> Hi all,
> different files.
> type="transition"/>
> </model:Diagram>
> </artifacts>
> name="Pool">
> </pools>
> </bpmn:BpmnDiagram>
> Thanks very much!
Re: how to save model file using xmi? [message #635481 is a reply to message #635400] Wed, 27 October 2010 02:16 Go to previous messageGo to next message
Member
Ed Merks wrote on Tue, 26 October 2010 11:44
I have already use the extension:
   <extension point="org.eclipse.emf.ecore.extension_parser" id="resource-factory">
      <?gmfgen generated="true"?>
      <parser
         type="apj"
         class="org.eclipse.gmf.runtime.emf.core.resources.GMFResourceFactory">
      </parser>
   </extension>
And the GMFResourceFactory is the subclass of XMIResourceFactoryImpl. I guess it will use XMIResourceImpl to serialize my model. Need I to do something more?
I'm a beginner of GMF, So could you give me a detail explain?
Thanks.
Re: how to save model file using xmi? [message #635561 is a reply to message #635481] Wed, 27 October 2010 10:57 Go to previous message
It sounds like you'll want to use XMIResource.OPTION_USE_XMI_TYPE.
>> instances for serializing and deserializing your model.
> <parser
> type="apj"
> class=" org.eclipse.gmf.runtime.emf.core.resources.GMFResourceFactor y ">
> </parser>
> </extension>
> do something more?
> Thanks.
Previous Topic:Cut, Copy, Paste EditPart: how to inhibit?
Next Topic:Custom behaviour for starting a swing application
Current Time: Thu Jun 21 01:20:17 GMT 2018
Powered by FUDForum. Page generated in 0.01664 seconds
