Home » Language IDEs » Java Development Tools (JDT) » JadClipse not opening class files
JadClipse not opening class files [message #635140] Mon, 25 October 2010 14:01 Go to next message
No real name is currently offline No real name
Hello all,
I am using:
- Eclipse Java EE IDE for Web Developers
Version: Helios Service Release 1
Build id: 20100917-0705
- JadClipse Class file viewer
My problem is:
When I go to open a class file I get the following error:
/*jadclipse*/
//Error!
I could not find anyone with the same error anywhere that I searched. The jadclipse is set to the default class editor and the jad.exe path is correct. Could it be a setting issue? Idk, please help.
Thank You,
Phil
Re: JadClipse not opening class files [message #635197 is a reply to message #635140] Mon, 25 October 2010 18:51 Go to previous messageGo to next message
Eclipse User
Originally posted by: lhasadad.gmail.google.com
I have seen error opening class files with latest jadclipse.
On 10/25/2010 2:01 PM, wmuphil@yahoo.com wrote:
> Hello all,
> I am using:
> My problem is:
> /*jadclipse*/
> //Error!
> Thank You,
> Phil
Re: JadClipse not opening class files [message #646306 is a reply to message #635140] Thu, 23 December 2010 04:28 Go to previous messageGo to next message
angel  is currently offline angel
No Real Name wrote on Mon, 25 October 2010 14:01
Hello all,
I am using:
My problem is:
/*jadclipse*/
//Error!
Thank You,
Phil
[b] Hi everybody
I face with same problem. I appreciate any help.
Thank you
Re: JadClipse not opening class files [message #748509 is a reply to message #646306] Mon, 24 October 2011 14:28 Go to previous message
Tim Jowers is currently offline Tim Jowers
has anyone solved this problem?
Helios Service Release 2
double-click a .class file. Opens with:
/*jadclipse*/
//Error!
jad works fine on the .class file from the shell.
TimJowers
Previous Topic:auto tabbing ...
Next Topic:Calling Refactorings Programmatically
Current Time: Sat May 18 17:29:57 EDT 2013
Powered by FUDForum. Page generated in 0.03415 seconds
