Home » Modeling » Modeling (top-level project) » Text to Model Transformation
Text to Model Transformation [message #635033] Mon, 25 October 2010 09:30 Go to next message
No real name is currently offline No real name
Hello everyone,
at first I will give u a short resumee about what I want to do in general.
I've got a DSL script, which is based on a Xtext grammar.
The main goal is to visualize the script in some kind of UML Activity diagramm.
I've got some ideas about using jface data binding and gmf, but here it's absolutely necessary to have some Datamodel in the beginning ( Ecore-Model e.g.) And thats where I stuck right now.
How do I transform the DSL script into an Ecore Model ?
Maybe I am totally on a wrong track , are there different approaches ? The Model-View-Controller attempt appeared to me the right thing to do it.
Thanks for your help
Greets
Tim
Re: Text to Model Transformation [message #635045 is a reply to message #635033] Mon, 25 October 2010 10:10 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Tim,
Comments below.
junk.mrt@gmx.net wrote:
> Hello everyone,
> general.
> I've got a DSL script, which is based on a Xtext grammar. The main
I'm not sure if we're off on some meta-level mismatch. If you have an
Xtext grammar, you already have an Ecore model for your DSL. If you
want to transform an instance of this Ecore model to be an instance of
Ecore itself, that's another question. But given you want to visualize
your instance graphically, I don't see a need for that.
> it.
GMF should already be able to work directly with the Ecore model you
derive from your Xtext grammar...
> Greets Tim
Re: Text to Model Transformation [message #635088 is a reply to message #635045] Mon, 25 October 2010 11:32 Go to previous messageGo to next message
thanks for the fast answer
I got the ecore model of the xtext grammar thats right.
The thing is to visualize the dsl script that is written in the editor, which is based on the Xtext grammar. And to make some diagramm out of the script I have to transform it into kind of Metamodel, preferably to an ecore model , which GMF is able to work with
Re: Text to Model Transformation [message #635127 is a reply to message #635088] Mon, 25 October 2010 13:00 Go to previous messageGo to next message
Tim,
Comments below.
Again, I think there is a meta-level mismatch. You have an Ecore model
for the DSL. GMF can work with that to let you visualize instances of
your DSL graphically. If you literally want to convert instances of
your DSL to Ecore, that's another story. Things like XSDEcoreBuilder
will convert XML Schema instances of Ecore instances, so you could look
at how that's done. But given that I know nothing about your DSL,
there's nothing concrete I can say about mapping it to Ecore or whether
it even make sense. It wouldn't make sense, for example, to map the
Library model to Ecore...
Re: Text to Model Transformation [message #635190 is a reply to message #635088] Mon, 25 October 2010 18:18 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian Zarnekow
Hi Tim,
please have a look at the GMF integration example and the xtext
documentation (F1 in eclipse or www.xtext.org).
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 25.10.10 17:32, schrieb Tim Joussen:
Re: Text to Model Transformation [message #635310 is a reply to message #635190] Tue, 26 October 2010 07:28 Go to previous message
I think you were right about the Meta-Meta Problem Smile
http://www.eclipse.org/Xtext/documentation/1_0_0/images/emf-integration.png
this pic from the xtext guide makes it a bit easier to me to understand how the transformation from xtext to ecore works.
for more detailed questions I will post sooner or later Wink
thanks fpor your help!
Previous Topic:Data type and configuring to existing DB
Next Topic:Interrogating ecore model and programmatically generating model instances
Current Time: Wed Jun 19 05:31:16 EDT 2013
Powered by FUDForum. Page generated in 0.01896 seconds
