Home » Eclipse Projects » Subversive » No SVN submenu under Team menu in Preferences(I'm using Ubuntu 10.10 and Eclipse 3.5.2.)
icon5.gif  No SVN submenu under Team menu in Preferences [message #634826] Sun, 24 October 2010 04:16 Go to next message
Guisardo is currently offline GuisardoFriend
I'm using Ubuntu 10.10 and Eclipse 3.5.2 (all fully updated)
I can't make Subversive work on my computer. No svn team menu, svn view or svn perspective option is displayed. I've tried installing from the helios, early and headless repository without success.
I've erase and purge Eclipse from my pc and reinstalled from scratch but that didn't do the trick.
I've tried installing libsvn-java package and adding
-Djava.library.path=/usr/lib/jni
to eclipse.ini but nothing happens.
Eclipse seems to compile and build just fine and no error were throw at the plugin installation.
Can anyone helpme? is there any way to debug or log anything that may help?
Re: No SVN submenu under Team menu in Preferences [message #645701 is a reply to message #634826] Mon, 20 December 2010 03:40 Go to previous message
No real name is currently offline No real nameFriend
I have exactly the same problem, i'm using Ubuntu 10.10 64 bits. Nevertheless SVN works fine in my virtual machine with ubuntu 10.04 32 bits.
Does anyone have an idea? Razz
Previous Topic:Cancel Commit
Next Topic:svn problem accessing projects containing resources from a not loaded model
Current Time: Fri Jan 19 15:47:48 GMT 2018
Powered by FUDForum. Page generated in 0.01895 seconds
