Home » Eclipse Projects » XML Schema Definition (XSD) » Cross-referencing namespaces & schemas
Cross-referencing namespaces & schemas [message #634816] Sat, 23 October 2010 23:19 Go to next message
No real name is currently offline No real nameFriend
I have 2 XSDs, each describing their own namespace.
I'd like to use elements from both XSDs in the other XSD, and so I import the other namespace in each file.
However, the XSD no longer validate properly - I'm getting 'sch-props-correct.2: A schema cannot contain two global components with the same name; this schema contains two occurrences of...'
The XSDs seem perfectly valid, and xjc happily generates usable code, so I'd be interested to know why validation doesn't handle this case, and how to address that.
Any tips or clues?
Frederik
Re: Cross-referencing namespaces & schemas [message #634818 is a reply to message #634816] Sun, 24 October 2010 00:09 Go to previous message
Frederik,
Comments below.
fle@alkasa.be wrote:
> Hi
What doe the imports look like?
What's that?
It's kind of hard to answer without being able to reproduce the problem.
> Any tips or clues?
The error message you describe looks more like one generated by Xerces...
> Thanks
> Frederik
Previous Topic:Querying parents of element declarations
Next Topic:Ant Problem - failed to create task or type project
Current Time: Sun May 27 21:50:26 GMT 2018
Powered by FUDForum. Page generated in 0.01953 seconds
