Home » Language IDEs » Java Development Tools (JDT) » How can I pass arguments to the main method?
How can I pass arguments to the main method? [message #634752] Sat, 23 October 2010 00:04 Go to next message
Nishika N Jones is currently offline Nishika N Jones
1. Choose Options from the Configure menu.
2. Select JDK Tools, select Run Application from the pulldown list, Edit.
3. The Tool Configurations dialog box will be displayed.
4. Enable the checkbox ''Prompt for main method arguments"
Is there anyother way apart from this.
Re: How can I pass arguments to the main method? [message #634856 is a reply to message #634752] Sun, 24 October 2010 13:02 Go to previous messageGo to next message
Stephan Herrmann is currently offline Stephan Herrmann
Nishika N Jones wrote on Sat, 23 October 2010 06:04
I don't see any of these menus/options.
Which tool exactly are you using?
Stephan
Re: How can I pass arguments to the main method? [message #656499 is a reply to message #634856] Fri, 25 February 2011 17:45 Go to previous messageGo to next message
Phil Freihofner is currently offline Phil Freihofner
Member
Hi - I was similarly trying to figure out how to pass arguments to a "main" that expects input, and came across the above cryptic exchange. (Seems like some posts are missing? I see just two posts.)
Here is what I ended up doing, using Helios.
Select Run --> Run Configurations...
Select tab: "(x)= Arguments"
Entered my arguments in the text box labeled "Program arguments:"
Click Run.
The arguments entered persist with the click of the Run shortcut.
Perhaps there is a way to have the IDE prompt for arguments, which would beat having to click through to the "Program arguments:" text box each time. Still, having this option is better than nothing!
Re: How can I pass arguments to the main method? [message #656503 is a reply to message #656499] Fri, 25 February 2011 18:14 Go to previous messageGo to next message
Member
I just figured out another option for passing arguments to main: use the Scrapbook! The following syntax works for a single argument. Note that the arguments have to be within a string array.
String[] input = {"MyInput1"};
MyClass.main( input );
Highlight the entire in the scrapbook, right click and select "Execute".
Instructions for making a Scrapbook can be found via a Help Search on "scrapbook". If there is an even easier way, I'd love to know about it! Thanks.
Re: How can I pass arguments to the main method? [message #656517 is a reply to message #656499] Sat, 26 February 2011 00:49 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
> Click Run.
> Perhaps there is a way to have the IDE prompt for arguments, which would beat having to click through to the "Program arguments:" text box each time.. Still, having this option is better than nothing!
You can use the Eclipse Variables feature in the Run Configurations
dialog. While on the Arguments Tab, click on the Variables Button. In
the popup dialog is a list of variables that Eclipse will substitute
when running the launch config. One of the variables is String Prompt.
This allows you to enter a prompt string with a text field where the
user can enter any text. The prompt will be shown at each launch. You
can even enter default data.
The variable ${string_prompt:Enter program args:One} will cause Eclipse
to display a popup with the prompt Enter Program args on one line and a
text field filled in with One.
Re: How can I pass arguments to the main method? [message #657428 is a reply to message #656517] Wed, 02 March 2011 13:34 Go to previous message
Member
Yay! Thank you.
Previous Topic:JRE_CONTAINER empty when creating a new JavaProject
Next Topic:run from command line
Current Time: Wed Jun 19 17:44:56 EDT 2013
Powered by FUDForum. Page generated in 0.05344 seconds
