Home » Modeling » EMF » Cannot create an instance of my model in my editor
Cannot create an instance of my model in my editor [message #634488] Thu, 21 October 2010 22:22 Go to next message
Jon Svede is currently offline Jon SvedeFriend
Member
I am using EMF 2.5.
I created a simple ecore model, then generated the .genmodel. From the genmodel, I right clicked an selected "Generate all" - which all worked as expected.
Then I run the IDE, create a new project and then attempt to create an instance of my model from the "Example EMF Model Creation Wizards" and start walking through the pages. However, when I get to the last page, the one where you select the root element, the finish and next buttons are never enabled. No matter what I select, they are disabled.
I am assuming I did something wrong but I can't see what it is. I've added -consoleLog to the launch config and there is no .log being created.
Any suggestions?
Jon
Re: Cannot create an instance of my model in my editor [message #634687 is a reply to message #634488] Fri, 22 October 2010 18:12 Go to previous messageGo to next message
Member
I did some testing to see if I could isolate the issue. I think it's related to being on a Mac:
On Windows:
1. I created a simple ecore model, genmodel and then model, edit, editor and tests.
2. Launched eclipse, created a new project, added an instance of my model and populated it.
3. saved the model, confirmed the file contents.
4. Copied these 4 projects to my mac.
On OS X:
1. Installed a fresh copy of eclipse-modeling-galileo-SR2-incubation-macosx-cocoa.tar.gz .
2. Launched new eclipse instance, created new clean workspace.
3. Imported 4 projects from windows env and copied them to the workspace.
4. Launched eclipse and attempted to repeat step #2 above; the results are as previously described: I cannot create an instance of the model, the next/finish buttons are not enabled.
Is there some special flag I have to add to the launch to make it work on OS X? I am on 10.6.4.
As an aside, when you are working on an ecore or genmodel on OS X, when you select an item in the Properties View that has a white background (the Properties View on OS X has alternating row colors, light blue and white), upon selecting that row for editing the label temporarily disappears (I assume it's background/foreground color issue) - is there a setting I can set to fix that?
Thanks in advance!
Jon
Re: Cannot create an instance of my model in my editor [message #634698 is a reply to message #634488] Fri, 22 October 2010 18:11 Go to previous messageGo to next message
Jon,
This sounds familiar. I think it was an SWT bug. I think if you choose
some other type of object to create on that last page, it will enable...
Jon Svede wrote:
> I am using EMF 2.5.
> worked as expected.
> created.
> Any suggestions?
> Jon
Re: Cannot create an instance of my model in my editor [message #634699 is a reply to message #634698] Fri, 22 October 2010 18:31 Go to previous messageGo to next message
Member
Thanks, Ed.
Unfortunately no matter what I select, or what encoding I choose, the Next/Finish buttons never enabled.
Any other ideas?
I don't see a .log in the runtime workspace of the launched Eclipse instance. I don't see .log file in my workspace either. No errors are getting logged to the console. I have the -consoleLog on the launch config but nothing shows up.
Jon
Re: Cannot create an instance of my model in my editor [message #634705 is a reply to message #634687] Fri, 22 October 2010 18:45 Go to previous messageGo to next message
Jon,
As I said, the issue sounds very familiar. I'm pretty sure that
choosing a different type of roog object in the drop down will enable
the button...
> On Windows:
> editor and tests.
> On OS X:
> Thanks in advance!
> Jon
Re: Cannot create an instance of my model in my editor [message #634735 is a reply to message #634705] Fri, 22 October 2010 21:12 Go to previous messageGo to next message
Member
I will search in Bugzilla to see I can past it. As I said, using a model that works fine on Windows, I cannot create an instance in the editors regardless of which Object I select.
Thanks, Jon
Re: Cannot create an instance of my model in my editor [message #648442 is a reply to message #634735] Wed, 12 January 2011 22:51 Go to previous messageGo to next message
aurelienfaravelon is currently offline aurelienfaravelonFriend
I seem to have a similar problem, did you solve yours?
Thanks in advance,
A.
Re: Cannot create an instance of my model in my editor [message #648465 is a reply to message #648442] Thu, 13 January 2011 02:03 Go to previous messageGo to next message
Which version of Eclipse/EMF are you using?
aurelienfaravelon@gmail.com wrote:
> Thanks in advance,
> A.
Re: Cannot create an instance of my model in my editor [message #648466 is a reply to message #648442] Thu, 13 January 2011 02:52 Go to previous message
Member
I did not solve it. I had to move onto other work and could not spend more time on it. I found that contrary to the advice given, selecting other objects had no affect I still could not instantiate the model.
Since I have two computers, my solution was to use the Windows machine. Sad
[Updated on: Thu, 13 January 2011 02:53]
Report message to a moderator
Previous Topic:I can't use my model editor
Next Topic:Wrong schemaLocation in Ecore file when using URI maps
Current Time: Mon Jun 18 10:01:58 GMT 2018
Powered by FUDForum. Page generated in 0.01923 seconds
