Home » Modeling » TMF (Xtext) » Problems with terminal rules...
Problems with terminal rules... [message #634312] Thu, 21 October 2010 09:08 Go to next message
Fran Blanco is currently offline Fran BlancoFriend
I want to create a DSL and i am having some problems...
I have some kind of variables:
INT --> +- 0...9
DEC ---> +- 0...9 . 0...9
LGL ---> '0' or '1'
CHAR --> A....Z 0....9 eg. YESNO or '1234' or 'YESNO'
I have the problem with CHAR variable. I can introduce this kind of variable of different ways:
YESNO
'YESNO'
'ASDD1234'
ASD1ASD
between quotes or not...
Here is my Code:
grammar org.xtext.prueba with org.eclipse.xtext.common.Terminals
generate prueba "http://www.xtext.org/prueba"
Model:
CLStatementInicial;
terminal ENTEROS:
('-')? ('0'..'9')+;
terminal DECIMAL:
(ENTEROS) ('.')? (ENTEROS)?;
terminal GENERAL:
('A'..'Z') ('A'..'Z' | '0'..'9')*;
terminal PARAMETRO:
('&') ('A'..'Z') ('A'..'Z' | '0'..'9')*;
terminal PROCEDURE:
('A'..'Z' | '0'..'9' | '_')+;
terminal DIRECTORIO:
('A'..'Z' | '0'..'9' | '/' | '_')+;
terminal CHAR: //Espacios da ERROR
"'"? ('A'..'Z' | '0'..'9' | '/' | '_' | '.')+ "'"?;
enum LISTATIPOSPARAMETRO:
CHAR = '*CHAR' |
DEC = '*DEC' |
LGL = '*LGL' |
INTEGER = '*INT' |
UINT = '*UINT';
//DefiniciĆ³n estructura Valores...
NumeroINT:
Value=(ENTEROS);
NumeroDEC:
Value=(DECIMAL);
NumeroCHAR:
Value=(CHAR);
NumeroLGL:
Value=("'0'" | "'1'");
Valor:
NumeroINT |
NumeroDEC |
NumeroCHAR |
NumeroLGL;
CLStatementInicial:
DCL:
'DCL'
('VAR'? '('? (parametro=PARAMETRO) ')'?)
('TYPE'? '('? (listatipos=LISTATIPOSPARAMETRO) ')'?)
('LEN'? '('? (length=ENTEROS) (length2=ENTEROS)? ')'?)?
(valor1=NumeroLGL |('VALUE' '(' (valor=Valor) ')'))?
When I introduce a CHAR with quotes is fine, but if i dont do it, doesnt work....
What could it be the correct structure of terminal rules?
Im so lost....
Thanks you..!
B
Re: Problems with terminal rules... [message #634330 is a reply to message #634312] Thu, 21 October 2010 09:52 Go to previous messageGo to next message
Jan Koehnlein is currently offline Jan KoehnleinFriend
Your terminal rules overlap, e.g. "'1'" will match LGL as well as CHAR,
"0" will match INT as well ad DEC. As the internal Antlr lexer is
context-less this can yield very strange behaviour, as the first
matching terminal rule wins. It's generally a better idea to use a
minumum set of terminal rules and cover the rest in datatype rules,
which are evaluated by the parser thus dealing with lookahead etc, e.g.
Int returns ecore::EInt :
(-|+)? INT;
Dec:
(-|+)? INT '.' INT?
terminal INT:
('0'..'9')+;
Into the bargain, your character rule matches 'a as well as a' or 'a'.
You should rather use an alternative covering either quotes on both ends
or none, as we do in the STRING rule in
/org.eclipse.xtext/src/org/eclipse/xtext/common/Terminals.xt ext
Am 21.10.10 11:08, schrieb Fran Blanco:
> INT --> +- 0...9
> LGL ---> '0' or '1'
> YESNO
> 'YESNO'
> 'ASDD1234'
> ASD1ASD
> Here is my Code:
> Quote:
>> Model:
>> CLStatementInicial;
>> terminal ENTEROS:
>> ('-')? ('0'..'9')+;
>> terminal DECIMAL:
>> terminal GENERAL:
>> terminal PARAMETRO:
>> terminal PROCEDURE:
>> CHAR = '*CHAR' |
>> DEC = '*DEC' |
>> LGL = '*LGL' |
>> INTEGER = '*INT' |
>> UINT = '*UINT';
>> NumeroINT:
>> Value=(ENTEROS);
>> NumeroDEC:
>> Value=(DECIMAL);
>> NumeroCHAR:
>> Value=(CHAR);
>> NumeroLGL:
>> Valor:
>> NumeroINT |
>> NumeroDEC |
>> NumeroCHAR |
>> NumeroLGL;
>> CLStatementInicial:
>> DCL: 'DCL' ('VAR'? '('? (parametro=PARAMETRO) ')'?)
> work....
> Im so lost....
> Thanks you..!
> B
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Get professional support from the Xtext committers at www.typefox.io
Re: Problems with terminal rules... [message #634549 is a reply to message #634312] Fri, 22 October 2010 07:39 Go to previous messageGo to next message
Hi Jan,
Thank you for ur reply! I think i have got the solution of INT and DEC problem... Here we go:
Model:
		'PGM'
	('PARM' '(' (parametros+=PARAMETRO)+ ')' )?
	(OtrosStatements+=Statements)*
	'ENDPGM';
terminal PARAMETRO:
DATAINT:
('-'|'+')? INT;
DATADEC:
('-'|'+')? INT '.' INT;
Valor:
DATAINT |
DATADEC;
CHAR = '*CHAR' |
DEC = '*DEC' |
LGL = '*LGL' |
INTEGER = '*INT' |
UINT = '*UINT';
Statements:
	'DCL'
	('LEN'? '('? (INT) (INT)? ')'?)?
	('VALUE' '(' (Valor) ')')?
What do you think? Its right?
After that, CHAR variable must have uppercases and numbers only. For example:
YESNO
YES123NO
'YESNO'
'YES123NO'
I m trying to put together INT rule with a uppercase letter rule, but RULE_INT fails... i have tried use a datatype too but I havent got it.. I dont know how to do it..!
Quotes issue i havent tried it yet... :S
But I have looked at terminal STRING and i dont understand the structure:
terminal STRING :
'"' ( '\\' ('b'|'t'|'n'|'f'|'r'|'"'|"'"|'\\') | !('\\'|'"') )* '"' |
"'" ( '\\' ('b'|'t'|'n'|'f'|'r'|'"'|"'"|'\\') | !('\\'|"'") )* "'";
But i could do a datatype like that:
DATACHAR2:
("'") DATACHAR ("'") |
DATACHAR;
Thank you so much again.
B
Edit:
I am trying right now and i cannot do it.
terminal UPPER:
"'" ('A'..'Z' | '0'..'9')+ "'" |
('A'..'Z' | '0'..'9')+;
The following token definitions are unreachable: RULE_INT..
[Updated on: Fri, 22 October 2010 08:18]
Report message to a moderator
Re: Problems with terminal rules... [message #634562 is a reply to message #634549] Fri, 22 October 2010 08:53 Go to previous messageGo to next message
Meinte Boersma is currently offline Meinte BoersmaFriend
Yup, UPPER will consume "1234" (without the single quotes) as well, so it shadows INT. Look at the default terminals' definitions to see what the pattern looks like for things like
'1234'
A1234
etc.
Re: Problems with terminal rules... [message #634567 is a reply to message #634312] Fri, 22 October 2010 09:25 Go to previous messageGo to next message
Hi!
The first one, i can write it with a STRING.
The second one with ID, but I couldnt use ID rule if i would want to write 1ASD23 cuz it needs to start with a letter...
Re: Problems with terminal rules... [message #634926 is a reply to message #634312] Mon, 25 October 2010 07:30 Go to previous messageGo to next message
I have been thinkin about it in the weekend and I havent got anything... I dont get to define a datatype or rule with UPPERCASE and numbers :S
I am going on with my DSL structure but i need to define this rule as soon as possible...
Any help??
Thz
B
Re: Problems with terminal rules... [message #635078 is a reply to message #634926] Mon, 25 October 2010 15:17 Go to previous messageGo to next message
Alexander Nittka is currently offline Alexander NittkaFriend
my general comment is: Make terminal rules non-overlapping and define as few terminals as possible, overwrite the default terminals (only) where it is sensible to do so (you may have to adapt the value converters then). Try to use datatype rules as much as possible (if you don't specify a return type the string that is read from the model is stored). You can add value converters throwing exceptions if the format (e.g. for LGL) incorrect.
That is use
Lgl returns <sensibledatatype>: INT;
and in the value converter test that the INT is in fact only 0 or 1.
Write tests for terminal and datatype rules (see http://blogs.itemis.de/stundzig/archives/726 for inspiration).
Often it is easier not to put everything in the grammar (terminal rules) but have semantic validation (allowing for user friendly error messages).
Basically everything of the following rules should be datatype rules rather than terminal rules.
>> terminal ENTEROS:
>> ('-')? ('0'..'9')+;
>> terminal DECIMAL:
>> terminal GENERAL:
>> terminal PARAMETRO:
>> terminal PROCEDURE:
Alex
Re: Problems with terminal rules... [message #635293 is a reply to message #634312] Tue, 26 October 2010 09:56 Go to previous message
Thz so much Alex, im workin on it right now.
Previous Topic:Community Contributions on Xtext website
Next Topic:Explicit setting of a rule's attribute
Current Time: Thu Feb 22 17:27:33 GMT 2018
Powered by FUDForum. Page generated in 0.06438 seconds
