Home » Eclipse Projects » Remote Application Platform (RAP) » a check button in scrolledComposite
| a check button in scrolledComposite [message #633007] |
Thu, 14 October 2010 23:44  |
roy Messages: 13 Registered: July 2010 |
Junior Member |
Hi All:
There is a check button in the scrolledComposite, when the mouse cursor
hover over this button , I can not scroll the composite use the wheel,
who can give me some advice ?
| Re: a check button in scrolledComposite [message #633460 is a reply to message #633109] |
Mon, 18 October 2010 02:24   |
Junior Member |
Hi Ivan:
Thanks for your repeat! I have test this problem with RAP1.4M2, and the
problem still exist!
Here is my test code:
public void createPartControl(Composite parent) {
ScrolledForm form = new ScrolledForm(parent);
Composite bodyComp = form.getBody();
bodyComp.setLayout(new GridLayout());
bodyComp.setLayoutData(new GridData(GridData.FILL_BOTH));
Composite composite = new Composite(bodyComp, SWT.NONE);
composite.setLayout(new GridLayout());
composite.setLayoutData(new GridData(GridData.FILL_BOTH));
for(int i = 0; i < 30; i++) {
Composite temp = new Composite(composite, SWT.NONE);
temp.setLayout(new GridLayout(4, false));
temp.setLayoutData(new GridData(GridData.FILL_BOTH));
for(int j = 0; j < 4; j++) {
Button btn = new Button(temp, SWT.RADIO);
btn.setText(j + "-" + i);
btn.pack();
Best Regards!
Roy
于 10/15/2010 07:53 PM, Ivan Furnadjiev 写道:
> Hi Roy,
> I can't reproduce it with current CVS HEAD (1.4M2). Which version of RAP
> are you using?
> Best,
> Ivan
> On 10/15/2010 6:44 AM, Roy Xiao wrote:
>> Hi All:
| Re: a check button in scrolledComposite [message #633477 is a reply to message #633460] |
Mon, 18 October 2010 03:28   |
Ivan Furnadjiev Messages: 1461 Registered: July 2009 |
Hi Roy,
yes... I can confirm this, but only with radio buttons. Scrolling works
fine with check and toggle buttons. Please file a bugzilla with this
snippet attached to keep track on this issue.
Ivan
On 10/18/2010 9:24 AM, Roy Xiao wrote:
> Hi Ivan:
> and the problem still exist!
> btn.pack();
> Best Regards!
> Roy
>> Hi Roy,
>> are you using?
>> Best,
>> Ivan
>>> Hi All:
| Re: a check button in scrolledComposite [message #633488 is a reply to message #633460] |
Mon, 18 October 2010 04:05   |
I've just opened a bug:
328013: [Button] Radio buttons stop the propagation of mouse wheel event
https://bugs.eclipse.org/bugs/show_bug.cgi?id=328013
> Hi Ivan:
> btn.pack();
> Best Regards!
> Roy
>> Hi Roy,
>> are you using?
>> Best,
>> Ivan
>>> Hi All:
| Re: a check button in scrolledComposite [message #633492 is a reply to message #633477] |
Mon, 18 October 2010 04:33  |
Junior Member |
Hi Ivan:
yes, only with radio buttons !
I am sorry for my clerical error!
Best Regards!
Roy
于 10/18/2010 03:28 PM, Ivan Furnadjiev 写道:
> Hi Roy,
> Ivan
>> Hi Ivan:
>> btn.pack();
>> Best Regards!
>> Roy
>>> Hi Roy,
>>> are you using?
>>> Best,
>>> Ivan
>>>> Hi All:
Current Time: Wed Jun 19 06:23:18 EDT 2013
Powered by FUDForum. Page generated in 0.01660 seconds
