Home » Modeling » TMF (Xtext) » terminals gets my knickers in a twist every time...
terminals gets my knickers in a twist every time... [message #632388] Tue, 12 October 2010 17:44 Go to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
With this specification of terminals:
terminal TEXTSTART : '«' !('»'|'‹')* '‹';
terminal TEXTMID : '›' !('»'|'‹')* '‹';
terminal TEXTEND : '›' !('»'|'‹')* '»';
terminal TEXT : '«' !('»'|'‹'|'›')* '»';
I manage to get a working switch between template and non template
parsing. Input could look something like:
var a = "Mary";
var b = "this morning";
«Hello ‹ a ›, how are you ‹ b ›?»
If I however switch to using two characters '<%' and '%>' instead of the
'UTF-8' characters '‹' and '›' (sort of "lower-case '«»'" ;) i.e.:
terminal TEXTSTART : '«' !('»'|'<%')* '<%';
terminal TEXTMID : '%>' !('»'|'<%')* '<%';
terminal TEXTEND : '%>' !('»'|'<%')* '»';
terminal TEXT : '«' !('»'|'<%'|'%>')* '»';
(and not changing anything else)
....then I get the following print out:
error(204):
.../org.eclipse.b3.beelang/src-gen/org/eclipse/b3/parser/ant lr/internal/InternalBeeLang.g:24002:39:
duplicate token type '%>' when collapsing subrule into set
What is it I am missing? or is this a bug? (which it almost never is
when things are not working as expected with terminals :)
What I really would like to have is '«{' and '}»' but I was afraid to
try this if I could not get the '%>' to work first
Any terminal [sic] help much appreciated :)
First working solution wins an ESE beer ...
- henrik
Re: terminals gets my knickers in a twist every time... [message #632429 is a reply to message #632388] Tue, 12 October 2010 20:41 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Henrik,
StringLiteral:
values+=TEXT
| values+=TEXTSTART values+=ID (values+=TEXTMID values+=ID)*
values+=TEXTEND
terminal TEXT : '[' ( (("%" !'>')|("<" !'%'))|!('%'|"<"|"]"))* ']';
terminal TEXTSTART : '[' ( (("%" !'>')|("<" !'%'))|!('%'|"<"|"]"))* '<' '%';
terminal TEXTEND : '%' '>' ( (("%" !'>')|("<" !'%'))|!('%'|"<"|"]"))* ']';
terminal TEXTMID : '%' '>' ( (("%" !'>')|("<" !'%'))|!('%'|"<"|"]"))*
parses:
[ content <% ID %> content <% ID %> content ];
[<% /* */ ID %><% /* */ ID %>];
[ content <% ID %> content /* */ ];
[ <% ID %> ];
[ ID ];
[ % % % > < arbitrary content ];
See you @ ESE ;-)
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 12.10.10 19:44, schrieb Henrik Lindberg:
> var a = "Mary";
> error(204):
> ../org.eclipse.b3.beelang/src-gen/org/eclipse/b3/parser/antl r/internal/InternalBeeLang.g:24002:39:
> Regards
> - henrik
Re: terminals gets my knickers in a twist every time... [message #632446 is a reply to message #632429] Wed, 13 October 2010 00:35 Go to previous message
WOOT !
(Hint «{=expr}» is an "echo", while «{expr}» just has side effects, but
can include printing of templates inline).
--- testingIfSebastianGetsABeer.b3
« This is a documentation clause with trimmed whitespace and
processing of \t as in Java String. It should have different
appearance in the editor than a Template.
Testing { }«} «
function testIfSebastianGetsBeer :
testIfConstructorGetsBeer("Sebastian", 2).print() ;
function testIfSomeoneGetsBeer(String someone, Integer pints) {
if pints < 0 then throw "no beer return" endif;
«The constructor of my terminal rules' logic, «{=someone}», is
hereby granted «{=
switch pints
case 0 : "no"
default : pints
endswitch
switch pints
case 0 : "beer"
case 1 : "pint"
default : "pints"
endswitch
}» since this template with stuff like { }«} parses ok «{="\u263A"}»!
Look out for the lo«{(0..pints).do(x|«o«{=x}»o».print()) }»op»;
function testing () {
var a = 1;
« content «{ a }» content «{ a }» content »;
««{ /* */ a }»«{ /* */ a }»»;
« content «{ a }» content /* */ »;
« «{ a }» »;
// ««{}»»; // uncomment for correct parse error (no expression)
// ««{=}»»; // uncomment for correct parse error (no expression)
« a »;
« } } } { { { « arbitrary content »;
// « » »; // uncomment for correct parse error (end end)
Now I should do "9 green bottles hanging on a wall" HTML template as an
exercise...
See you @ ESE ;-)
Sebastian
On 10/12/10 10:41 PM, Sebastian Zarnekow wrote:
> Hi Henrik,
> StringLiteral:
> values+=TEXT
> values+=TEXTEND
> parses:
> [ <% ID %> ];
> [ ID ];
> See you @ ESE ;-)
> Sebastian
Previous Topic:Xtext and macro expansion
Next Topic:[Xtext] Use Xtend in generator project -- how to define metamodels
Current Time: Mon May 21 07:34:44 GMT 2018
Powered by FUDForum. Page generated in 0.04925 seconds
