Home » Language IDEs » ServerTools (WTP) » Linked resources
Linked resources [message #631555] Thu, 07 October 2010 22:49 Go to next message
sasha is currently offline sashaFriend
Member
If I have a dynamic web project , and want my jsps to come from several
different projects in the eclipse workspace, how do I do it ?
Something to do with linked resources, not sure how to set it up and if it
will pick up my edits to the jsps in the respective projects after I have
deployed ...
Re: Linked resources [message #631582 is a reply to message #631555] Fri, 08 October 2010 05:55 Go to previous messageGo to next message
Kaloyan Raev is currently offline Kaloyan RaevFriend
Yes, if you try creating linked folders or files (depending on what exactly do you want to link), it should work as a charm. Just give it a try.
Re: Linked resources [message #631583 is a reply to message #631555] Fri, 08 October 2010 05:57 Go to previous messageGo to next message
If it is not clear how to do it...
Just go New > Folder. There is Advanced button that gives you the option to create a linked folder. You can also apply filters which resources from the origin folder to be picked up.
You have the same in New > File.
Re: Linked resources [message #631943 is a reply to message #631583] Sun, 10 October 2010 22:30 Go to previous messageGo to next message
I am stuck at a previous point before I can even get to that. Perhaps you
can help me. I am having trouble with jsp taglib uri not found for jsps in
the workspace that were created by importing an ear. I tried to copy the
same content to a different file and then it finds the uri without a
problem. Any amount of retouching saving editing the original file does not
fix the problem. There has to be some kind of cache of the taglibs and jsps
somewhere. that I can clear
I am running out of ideas...
thanks for your help
Re: Linked resources [message #631972 is a reply to message #631943] Mon, 11 October 2010 06:10 Go to previous message
Unfortunately, I am not an expert in JSP and Taglib technologies.
If you have easy steps to reproduce, then I recommend to a submit a bug.
If not, then it would be better to open a new topic in the forum, so the JSP experts in the community can spot it. The title of this topic will not catch their attention.
Previous Topic:Trouble with JavaServer Faces
Next Topic:Eclipse Helios WASCE v2.1 Integration
Current Time: Wed Jan 17 18:26:05 GMT 2018
Powered by FUDForum. Page generated in 0.02360 seconds
