Home » Eclipse Projects » SWTBot » Howto: SWTHelloWorld with SWTBot?
Howto: SWTHelloWorld with SWTBot? [message #631181] Wed, 06 October 2010 13:53 Go to next message
Andreas Heertsch is currently offline Andreas HeertschFriend
(sorry for this newbie quesiton)
How to use SWTBot with the HelloWorldSWT. Is there a tutorial around? (all tutorials I found handle with RCPs, but not "normal" java apps.)
in other words: is SWTBot able to run with applications, that are not plugins or RCP's?
if yes: is there an example around?
Andreas
[Updated on: Fri, 08 October 2010 14:09]
Report message to a moderator
Re: Howto: SWTHelloWorld with SWTBot? [message #636412 is a reply to message #631181] Mon, 01 November 2010 06:36 Go to previous message
toni  is currently offline toni Friend
Since there are few opensource tools support RCP (in fact, I just seen abbot and swtbot), from what I know, swtbot is designed to test RCP based App. If you wanna test another java application, you can use other tools which can help you peform your testing easier by providing record and playback function.
Refer to the list in this page for more tools: http://www.manageability.org/blog/stuff/open-source-automate d-test-tools-written-in-java
Previous Topic:Headless test report
Next Topic:when to use syncExec?
Current Time: Tue Jan 23 17:42:51 GMT 2018
Powered by FUDForum. Page generated in 0.01754 seconds
