Home » Newcomers » Newcomers » (MAC) Problem in Eclipse with GWT plugin on debugging
(MAC) Problem in Eclipse with GWT plugin on debugging [message #631173] Wed, 06 October 2010 09:09 Go to next message
kostas  is currently offline kostas
Hello i am new to Eclipse IDE.
I have MAC OS and I have downloaded the latest eclipse version for JAVA developers.
I want to use eclipse as an IDE support for GWT(Google Web Toolkit). I followed the instructions from google to install it's plugin.
The plugin i installed is:
Eclipse 3.6 (Helios)
http://dl.google.com/eclipse/plugin/3.6
I completed the installation successfully. So i jump in creating my first web application using the gwt framework.
I go to
FIle>New>New Web Application Project
Then i name my project and click to enable the Google SDK's (The Google Web Toolkit and the Google App Engine).
It creates all the files automatically then to deploy my web application i left click to my project Debug As>Web Application and then comes the build error:
'Launching MyWebApp' has encountered a problem:
An internal error occurred during: "Launching MyWebApp".
java.lang.NoClassDefFoundError
Any solutions please? Thanks in advance.
[Updated on: Wed, 06 October 2010 09:12]
Report message to a moderator
Re: (MAC) Problem in Eclipse with GWT plugin on debugging [message #631239 is a reply to message #631173] Wed, 06 October 2010 12:10 Go to previous messageGo to next message
Russell Bateman is currently offline Russell Bateman
> developers.
> I go to FIle>New>New Web Application Project
> build error:
> An internal error occurred during: "Launching MyWebApp2".
> java.lang.NoClassDefFoundError.
Why not try a tutorial to guide you through? Lars Vogel's are really good:
http://www.vogella.de/google.html
Re: (MAC) Problem in Eclipse with GWT plugin on debugging [message #631307 is a reply to message #631239] Wed, 06 October 2010 19:05 Go to previous messageGo to next message
Thanks for the tutorial, it is really good and useful. However the tutorial cannot solve an eclipse or GWT bug such as the reported. I followed the official google tutorial with precision and unfortunately it resulted to errors.
1)An error has occurred. See error log for more details.
2)An internal error occurred during: "Launching HelloWorld".
Any further assistance please?
http://dl.dropbox.com/u/1035468/Picture%202.png
[Updated on: Wed, 06 October 2010 19:10]
Re: (MAC) Problem in Eclipse with GWT plugin on debugging [message #634508 is a reply to message #631173] Thu, 21 October 2010 23:11 Go to previous messageGo to next message
JerryGx Missing name is currently offline JerryGx Missing name
Same problem on a 32-bit CPU Leopard..
Re: (MAC) Problem in Eclipse with GWT plugin on debugging [message #634582 is a reply to message #634508] Fri, 22 October 2010 06:22 Go to previous message
I found the solution to another post of java forums
To solve the issue:
1. Decompress the com.ibm.icu_4.0.1.v20090822.jar file in the eclipse/plugins folder to any directory you like
If you cannot find the exact version, just decompress the IBM ICU JAR that's shipped with your version of Eclipse
2. In that directory, open the file com/ibm/icu/ICUConfig.properties
3. Replace
com.ibm.icu.util.TimeZone.DefaultTimeZoneType = JDK
with
com.ibm.icu.util.TimeZone.DefaultTimeZoneType = ICU
4. Recompress the com.ibm.icu_4.0.1.v20090822.jar file in the eclipse/plugins folder with the modified file
Make sure Eclipse is started with a clean cache, and it should work. The easiest way of cleaning the Eclipse cache is to remove the .plugins folder of your workspace.
Previous Topic:Folder of projects
Next Topic:ShellEd install?
Current Time: Tue Oct 08 07:52:54 EDT 2013
Powered by FUDForum. Page generated in 0.01729 seconds
