Re: Change the location of the platform folder of the BIRT Servlet? [message #631204 is a reply to message #631128] |
Wed, 06 October 2010 14:55 |
Mika,
In that example if you do not want to use the web-inf/platform folder do
not create the PlatformServletContext and set a birt home ie:
config.setEngineHome("c:/mybirtplugins");
//IPlatformContext context = new PlatformServletContext( sc );
//config.setPlatformContext( context );
Jason
On 10/6/2010 5:47 AM, mika.tapanainen@digia.com wrote:
> Hello,
> I tried to use
> osgi.install.area=file:/c:/birtRuntimePlugins2_6_1/
> but it didn't work. There was an exception:
> [5.10.2010 10:03:36:476 EEST] 0000003d SystemErr R
> org.eclipse.birt.core.exception.BirtException:
> error.CannotStartupOSGIPlatform
> [5.10.2010 10:03:36:492 EEST] 0000003d SystemErr R at
> org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:92)
> pdf.BirtEngine.getBirtEngine(BirtEngine.java:82)
> pdf.PDFServlet.init(PDFServlet.java:275)
> My servlet is based on the BIRT 2.5 example on the page:
> http://wiki.eclipse.org/Servlet_Example_%28BIRT%29_2.1
> Is it possible to have a plugins folder outside of the war package and
> use osgi.install.area or other configuration parameter?
> BR,
> Mika
FUDForum. Page generated in 0.02881 seconds
