Home » Eclipse Projects » EclipseLink » Compatibility of TABLE_PER_CLASS inheritance strategy with composite keys
Compatibility of TABLE_PER_CLASS inheritance strategy with composite keys [message #630514] Sun, 03 October 2010 16:44 Go to next message
dcarbonne  is currently offline dcarbonne Friend
Is there any (JPA) defined incompatibility between the TABLE_PER_CLASS inheritance strategy and the use of composite key?
With the following entities:
- BaseId: embeddable entity (to be used as embedded id)
- Base: base class, whose embedded id is BaseId and inheritance strategy is TABLE_PRE_CLASS
- Derived1: class derived from Base
EclipseLink (2.1.1) fails throwing an exception:
Exception [EclipseLink-74] (Eclipse Persistence Services - 2.1.1.v20100817-r8050): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: The primary key fields are not set for this descriptor.
Descriptor: RelationalDescriptor(jpa03.Derived1 --> [DatabaseTable(DERIVED1)])
However, changing the Base key from BaseId to any simple primary key (e.g. int), things work correctly.
So, is this a JPA limitation or an EclipseLink limitation / bug?
I have read that TABLE_PER_CLASS is optional, so it may well be an EclipseLink limitation, but I did not find any explicit statement about this.
Damien Carbonne
Re: Compatibility of TABLE_PER_CLASS inheritance strategy with composite keys [message #630657 is a reply to message #630514] Mon, 04 October 2010 13:50 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris DelahuntFriend
Can you post details on the EclipseLink version being used, the full stack trace from the error and the model being used? A similar setup exists in EclipseLink tests available at
https://fisheye2.atlassian.com/browse/eclipselink/trunk/jpa/ eclipselink.jpa.test/src/org/eclipse/persistence/testing/mod els/jpa/inheritance/Elimination.java?r=HEAD
https://fisheye2.atlassian.com/browse/eclipselink/trunk/jpa/ eclipselink.jpa.test/src/org/eclipse/persistence/testing/mod els/jpa/inheritance/DirectElimination.java?r=HEAD
Only difference is it is not using an EmbeddedId. Can you try directly mappiing the attributes on the base class instead?
Best Regards,
Chris
Re: Compatibility of TABLE_PER_CLASS inheritance strategy with composite keys [message #630768 is a reply to message #630657] Mon, 04 October 2010 21:16 Go to previous messageGo to next message
Thanks for answer.
I use latest EclipseLink (2.1.1.v20100917), under Linux, with Eclipse Helios.
The same behaviour exists under Windows using the same versions of EclipseLink and Eclipse.
Code follows. I could also send an archive of this small project.
I'll try to see if I can use IdClass instead of EmbeddedId.
Damien
jpa03/BaseId.java
package jpa03;
import java.io.Serializable;
import java.lang.String;
import javax.persistence.*;
@Embeddable
public class BaseId implements Serializable {
   private static final long serialVersionUID = 1L;
   private String code;
   public BaseId() { super(); }
   public String getCode() { return this.code; }
   public void setCode(String code) { this.code = code; }
   public boolean equals(Object other) {
      if (other == null)
         return false;
      if (!(other instanceof BaseId)) {
         return false;
      BaseId o = (BaseId) other;
      return this.code.equals(o.code);
   public int hashCode() {
      return code.hashCode();
jpa03/Base.java
package jpa03;
import jpa03.BaseId;
import static javax.persistence.InheritanceType.TABLE_PER_CLASS;
@Entity
@Inheritance(strategy = TABLE_PER_CLASS)
public class Base implements Serializable {
   @EmbeddedId
   private BaseId id;
   public Base() { super(); }
   public BaseId getId() { return this.id; }
   public void setId(BaseId id) { this.id = id; }
jpa03/Derived1.java
package jpa03;
import jpa03.Base;
@Entity
public class Derived1 extends Base implements Serializable {
   public Derived1() { super(); }
persistence.xml
<persistence version="2.0"
  xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
  xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd">
  <persistence-unit name="jpa-03" transaction-type="RESOURCE_LOCAL">
    <provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
    <class>jpa03.BaseId</class>
    <class>jpa03.Base</class>
    <class>jpa03.Derived1</class>
    <properties>
      <property name="javax.persistence.jdbc.driver" value="org.apache.derby.jdbc.EmbeddedDriver" />
      <property name="javax.persistence.jdbc.url" value="jdbc:derby:/home/damien/workspace/db/jpa03;create=true" />
      <property name="javax.persistence.jdbc.user" value="" />
      <property name="javax.persistence.jdbc.password" value="" />
      <property name="eclipselink.logging.level" value="FINE" />
      <property name="eclipselink.ddl-generation.output-mode"
        value="both" />
    </properties>
  </persistence-unit>
</persistence>
Finally, when executing <JPA Tools/Generate Tables from Entities ...> (after having removed the Data Base) the stack trace is:
[EL Config]: The access type for the persistent class [class jpa03.Base] is set to [FIELD].
[EL Config]: The access type for the persistent class [class jpa03.Derived1] is set to [FIELD].
[EL Config]: The access type for the persistent class [class jpa03.BaseId] is set to [FIELD].
[EL Config]: The alias name for the entity class [class jpa03.Derived1] is being defaulted to: Derived1.
[EL Config]: The alias name for the entity class [class jpa03.Base] is being defaulted to: Base.
[EL Config]: The table name for entity [class jpa03.Base] is being defaulted to: BASE.
[EL Config]: The column name for element [field code] is being defaulted to: CODE.
[EL Config]: The table name for entity [class jpa03.Derived1] is being defaulted to: DERIVED1.
[EL Info]: EclipseLink, version: Eclipse Persistence Services - 2.1.1.v20100817-r8050
[EL Fine]: Detected Vendor platform: org.eclipse.persistence.platform.database.JavaDBPlatform
[EL Config]: Connection(12590745)--connecting(DatabaseLogin(
	platform=>JavaDBPlatform
	user name=> ""
	datasource URL=> "jdbc:derby:/home/damien/workspace/db/jpa03;create=true"
[EL Config]: Connection(8310136)--Connected: jdbc:derby:/home/damien/workspace/db/jpa03
	User: APP
	Database: Apache Derby  Version: 10.5.1.1 - (764942)
	Driver: Apache Derby Embedded JDBC Driver  Version: 10.5.1.1 - (764942)
[EL Config]: Connection(14910620)--connecting(DatabaseLogin(
	user name=> ""
[EL Config]: Connection(11731442)--Connected: jdbc:derby:/home/damien/workspace/db/jpa03
	User: APP
[EL Severe]: Local Exception Stack:
Exception [EclipseLink-0] (Eclipse Persistence Services - 2.1.1.v20100817-r8050): org.eclipse.persistence.exceptions.IntegrityException
Descriptor Exceptions:
Runtime Exceptions:
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:471)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:406)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.postConnectDatasource(DatabaseSessionImpl.java:666)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:615)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:228)
	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:380)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.getServerSession(EntityManagerFactoryImpl.java:157)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:214)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:202)
	at org.eclipse.jpt.eclipselink.core.ddlgen.Main.perform(Main.java:86)
	at org.eclipse.jpt.eclipselink.core.ddlgen.Main.execute(Main.java:77)
	at org.eclipse.jpt.eclipselink.core.ddlgen.Main.main(Main.java:64)
	at org.eclipse.persistence.exceptions.DescriptorException.primaryKeyFieldsNotSepcified(DescriptorException.java:1347)
	at org.eclipse.persistence.descriptors.ClassDescriptor.selfValidationBeforeInitialization(ClassDescriptor.java:3565)
	at org.eclipse.persistence.descriptors.ClassDescriptor.validateBeforeInitialization(ClassDescriptor.java:5280)
	at org.eclipse.persistence.descriptors.ClassDescriptor.preInitialize(ClassDescriptor.java:3346)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:429)
Runtime Exceptions:
Runtime Exceptions:
Runtime Exceptions:
Exception in thread "main" javax.persistence.PersistenceException: Exception [EclipseLink-0] (Eclipse Persistence Services - 2.1.1.v20100817-r8050): org.eclipse.persistence.exceptions.IntegrityException
Runtime Exceptions:
	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:408)
Caused by: Exception [EclipseLink-0] (Eclipse Persistence Services - 2.1.1.v20100817-r8050): org.eclipse.persistence.exceptions.IntegrityException
Runtime Exceptions:
	... 6 more
Re: Compatibility of TABLE_PER_CLASS inheritance strategy with composite keys [message #630770 is a reply to message #630657] Mon, 04 October 2010 21:27 Go to previous messageGo to next message
I've filed bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=326973 after reproducing your model using the classes I outlined previously. Please vote for the bug to have it fixed.
In the mean time, a workaround is to avoid using the embeddedId and instead map the fields directly in the object, using the embedded class as the pk class.
Best Regards,
Chris
Re: Compatibility of TABLE_PER_CLASS inheritance strategy with composite keys [message #631023 is a reply to message #630770] Tue, 05 October 2010 20:53 Go to previous message
Thanks for doing this.
Damien
Previous Topic:MOXy/JAXB ClassCastException: attempting to cast bundleresource://.../JAXBContext.class to jar:file:
Next Topic:JPQL where condition problem
Current Time: Sat May 26 17:34:35 GMT 2018
Powered by FUDForum. Page generated in 0.02367 seconds
