Home » Eclipse Projects » Buckminster » NoClassDefFoundError when trying to create target platform using Hudson/Buckminster
NoClassDefFoundError when trying to create target platform using Hudson/Buckminster [message #629893] Wed, 29 September 2010 20:53 Go to next message
Daniel Ford is currently offline Daniel FordFriend
I'm trying to get Hudson and Buckminster to work together to build an
RCP. I think I have most things installed and configured correctly, but
I've run into an issue that I can't resolve.
Basically, I have a Hudson Job that whose purpose is to create the
target platform. It does this with the buckminster
"importtartgetdefinition" command using the target definition I use in
the IDE. Things seem to work until the command is executed at which
point I get a "NoClassDefFoundError".
Any ideas?
Dan
> [workspace] $ "C:\Documents and Settings\daford\.hudson\tools\Sun_Java_6_SE\bin\java.exe" "-Dbuckminster.output.root=C:\Documents and Settings\daford\.hudson\jobs\Create e4 Target Platform\workspace\buckminster.output" "-Dbuckminster.temp.root=C:\Documents and Settings\daford\.hudson\jobs\Create e4 Target Platform\workspace\buckminster.temp" -Xmx256m -Xmx1024m -jar "C:\Documents and Settings\daford\.hudson\tools\Default_Buckminster\buckminste r\plugins\org.eclipse.equinox.launcher_1.1.0.v20100507.jar " -application org.eclipse.buckminster.cmdline.headless -data "C:\Documents and Settings\daford\.hudson\jobs\Create e4 Target Platform\workspace" --loglevel info -S "C:\Documents and Settings\daford\.hudson\jobs\Create e4 Target Platform\workspace\commands.txt"
> INFO: importtargetdefinition '-A' '/C:/Documents and Settings/daford/.hudson/jobs/Create e4 Target Platform/workspace/com.forddaniel.arm.releng/targetPlatforms /e4RCP20100727.target'
> Archiving artifacts
> FATAL: Could not initialize class sun.nio.ch.FileChannelImpl
> java.lang.NoClassDefFoundError: Could not initialize class sun.nio.ch.FileChannelImpl
> at java.io.FileInputStream.getChannel(Unknown Source)
> at org.apache.tools.ant.util.ResourceUtils.copyResource(Resourc eUtils.java:469)
> at org.apache.tools.ant.util.FileUtils.copyFile(FileUtils.java: 519)
> at org.apache.tools.ant.util.FileUtils.copyFile(FileUtils.java: 481)
> at org.apache.tools.ant.util.FileUtils.copyFile(FileUtils.java: 310)
> at org.apache.tools.ant.taskdefs.Copy.doFileOperations(Copy.jav a:841)
> at hudson.FilePath$31$1CopyImpl.doFileOperations(FilePath.java: 1434)
> at org.apache.tools.ant.taskdefs.Copy.execute(Copy.java:523)
Re: NoClassDefFoundError when trying to create target platform using Hudson/Buckminster [message #629908 is a reply to message #629893] Wed, 29 September 2010 21:40 Go to previous messageGo to next message
I did a bit of experimentation and discovered that if I unchecked the
"Archive and publish an Eclipse Target Platform" option on the Hudson
Job then Job would complete without throwing the Error. I was using
".metadata/.plugins/org.eclipse.pde.core/.bundle_pool"
As the "Path to Target Platform"
Again, any ideas?
Dan
> Any ideas?
> Thanks
> Dan
>> "C:\Documents and
>> Archiving artifacts
>> at
Re: NoClassDefFoundError when trying to create target platform using Hudson/Buckminster [message #629953 is a reply to message #629908] Thu, 30 September 2010 06:20 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
No idea. A NoClassDefFoundError is generally an indication on classpath
problems of some sort. Perhaps a version incompatibility somewhere. A
class is found but it's definition cannot be initialized.
- thomas
> Again, any ideas?
> Thanks
> Dan
>> Any ideas?
>> Thanks
>> Dan
>>> "C:\Documents and
>>> Archiving artifacts
>>> at
Re: NoClassDefFoundError when trying to create target platform using Hudson/Buckminster [message #630119 is a reply to message #629953] Thu, 30 September 2010 16:04 Go to previous message
I installed an update to Java on my machine and now things magically
work. Go figure.
Thanks!
Dan
> - thomas
>> Again, any ideas?
>> Thanks
>> Dan
>>> Any ideas?
>>> Thanks
>>> Dan
>>>> "C:\Documents and
>>>> Archiving artifacts
>>>> at
Previous Topic:P2 Repository can not be found
Next Topic:Materializing non-Java and non-plugin projects
Current Time: Tue Apr 24 03:19:02 GMT 2018
Powered by FUDForum. Page generated in 0.02102 seconds
