Home » Language IDEs » Objectteams » CFLOW like behaviour?
CFLOW like behaviour? [message #629570] Tue, 28 September 2010 18:11 Go to next message
Jan Marc Hoffmann is currently offline Jan Marc HoffmannFriend
Member
Hey guys,
how would I archieve AspectJ CFLOW like behaviour? My guess would be adding both roles into a team and work with a team field. Is there a more elegant way of doing this?
greetings
Jan Marc
Re: CFLOW like behaviour? [message #629576 is a reply to message #629570] Tue, 28 September 2010 18:34 Go to previous messageGo to next message
Stephan Herrmann is currently offline Stephan HerrmannFriend
That's funny, just today I implemented a team that does
exactly, what in AspectJ you would use a cflow for.
Assuming the two triggers are in different classes it is as easy as:
team class Outer {
    protected team class Interceptor1 playedBy Base1 {
        trigger1 <- replace baseMethod1;
        callin void trigger1() {
            within (this)
                base.trigger1();
        protected class Interceptor2 playedBy Base2 {
            targetMethod <- before baseMethod2;
new Outer().activate();
The key here is that the nested team Interceptor1 is not active
by default but only while trigger1() is being executed.
I think everything is nicely kept local in one spot.
Would this work for your use cases?
best
Stephan
PS: I should definitely put this into the wiki.
Thanks for bringing this up.
Re: CFLOW like behaviour? [message #629723 is a reply to message #629570] Wed, 29 September 2010 11:28 Go to previous messageGo to next message
Member
Thanks, this helps. :=)
greetings
Jan Marc
Re: CFLOW like behaviour? [message #643663 is a reply to message #629570] Tue, 07 December 2010 18:58 Go to previous messageGo to next message
Member
This works nice for 1 trigger. But what about 2 or more trigger? No problem if they are from the same class... But what if they aren't? :=)
Re: CFLOW like behaviour? [message #643675 is a reply to message #643663] Tue, 07 December 2010 19:36 Go to previous messageGo to next message
Jan Marc Hoffmann wrote on Tue, 07 December 2010 19:58
Well, it looks like you have to split the Interceptor1.
However, in order to make all those share a common
infrastructure, why not use inheritance:
team class Outer {
    protected team class AbstractInterceptor1 {
            within (this)
                base.trigger1();
    protected team class Interceptor1_1 extends AbstractInterceptor1 playedBy Base1_1 {
    protected team class Interceptor1_2 extends AbstractInterceptor2 playedBy Base1_2 {
any problems? Smile
Stephan
Re: CFLOW like behaviour? [message #643681 is a reply to message #629570] Tue, 07 December 2010 20:06 Go to previous messageGo to next message
Member
I really like it. The only problem are Exceptions ...
@SuppressWarnings("restriction")
public team class GOTScannerAdaptor {
	protected abstract team class Interceptor {
		protected class GOTScanner playedBy Scanner {
		@SuppressWarnings("basecall")
			within(this) {
				try {
					base.trigger1();
				} catch (Exception e) {
					// hmm not nice ...
					e.printStackTrace();
	protected team class ScannerInterceptor1 extends Interceptor playedBy DeltaProcessor {
		@SuppressWarnings("decapsulation")
		trigger1 <- replace elementType;
	protected team class ScannerInterceptor2 extends Interceptor playedBy CompilationUnit {
		void trigger1() <- replace org.eclipse.jdt.core.dom.CompilationUnit reconcile(int astLevel, int reconcileFlags, WorkingCopyOwner workingCopyOwner, IProgressMonitor monitor);
Re: CFLOW like behaviour? [message #643688 is a reply to message #643681] Tue, 07 December 2010 20:40 Go to previous messageGo to next message
Jan Marc Hoffmann wrote on Tue, 07 December 2010 21:06
Why do you want to catch those exceptions?
"within" already takes care that activation is reverted
to the previous state regardless of exceptions.
do I miss anything?
Stephan
Re: CFLOW like behaviour? [message #643691 is a reply to message #629570] Tue, 07 December 2010 21:06 Go to previous message
Member
Without the try catch block I get the following error:
Unhandled exception type JavaModelException
at base.trigger1();
And what about the fragileCallin Binding warning at
and
Hmm ;/....
Previous Topic:When it gets bigger... Teamactivation or base when or nothing?
Next Topic:Modifying Type Declaration
Current Time: Mon May 28 09:23:57 GMT 2018
Powered by FUDForum. Page generated in 0.02032 seconds
