Home » Language IDEs » Java Development Tools (JDT) » HTTP Status 503 - This application is not currently available
HTTP Status 503 - This application is not currently available [message #629439] Tue, 28 September 2010 10:03
Alaa G is currently offline Alaa GFriend
Hi All,
I keep getting this error after deploying JSP application to Apache server. The Apache server is running Sun 5.1 and im developing using MAC + Eclipse
I'm doing an export for the project after I'm done developing to ".war" file and place that file in the Tomcat 6.0 "webapp" folder
When i try to access it from the browser i get this HTTP Error:
So i tried deploying the examples that comes with the Tomcat, and that worked fine in the server and I can access it fine. However when I create a project and export it, same error happens.
The file structure of the provided example is different than what is produced by eclipse.
Your help please, what am I doing wrong? Sad
The log shows this error:
SEVERE: Error deploying web application directory Millinnum_SSO_Module
java.lang.UnsupportedClassVersionError: Bad version number in .class file (unable to load class sa.edu.asas.millennium.SSOServlet_Module)
at org.apache.catalina.loader.WebappClassLoader.findClassIntern al(WebappClassLoader.java:2737)
at org.apache.catalina.loader.WebappClassLoader.findClass(Webap pClassLoader.java:1124)
at org.apache.catalina.loader.WebappClassLoader.loadClass(Webap pClassLoader.java:1612)
at org.apache.catalina.loader.WebappClassLoader.loadClass(Webap pClassLoader.java:1491)
at org.apache.catalina.startup.WebAnnotationSet.loadApplication ServletAnnotations(WebAnnotationSet.java:108)
at org.apache.catalina.startup.WebAnnotationSet.loadApplication Annotations(WebAnnotationSet.java:58)
at org.apache.catalina.startup.ContextConfig.applicationAnnotat ionsConfig(ContextConfig.java:297)
at org.apache.catalina.startup.ContextConfig.start(ContextConfi g.java:1078)
at org.apache.catalina.startup.ContextConfig.lifecycleEvent(Con textConfig.java:261)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent (LifecycleSupport.java:119)
at org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4540)
at org.apache.catalina.core.ContainerBase.addChildInternal(Cont ainerBase.java:791)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBas e.java:771)
at org.apache.catalina.core.StandardHost.addChild(StandardHost. java:546)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostC onfig.java:1041)
at org.apache.catalina.startup.HostConfig.deployDirectories(Hos tConfig.java:964)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig .java:502)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java :1277)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostCo nfig.java:321)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1053)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:785)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1045)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:445)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:519)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:581 )
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:592)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 89)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 4)
Thanks in advance,
Alaa G
Previous Topic:Using custom icons in a JFrame
Next Topic:Eclipse exceutes commented and recently deleted code
Current Time: Sun Apr 22 09:02:29 GMT 2018
Powered by FUDForum. Page generated in 0.02092 seconds
