Home » Language IDEs » C / C++ IDE (CDT) » gl/glaux.h not found(opengl, eclipse, c++, win 7)
gl/glaux.h not found [message #629316] Mon, 27 September 2010 18:54 Go to next message
No real name is currently offline No real nameFriend
i tried to getting started with opengl in eclipse.
I downloaded the cdt version of eclipse and i have mingw working.
normal projects compile without any problems.
When i try to compile a standard opengl prgram e.g., Lesson 01 then i get the follwing:
in line:
#include <gl\glaux.h>                                // Header File For The GLaux Library
Unresolved inclusion: <gl\glaux.h>
what do i have to do to get gl running properly?
Re: gl/glaux.h not found [message #629392 is a reply to message #629316] Tue, 28 September 2010 06:53 Go to previous message
Axel Mueller is currently offline Axel MuellerFriend
You should add the include path for the external library.
In Project Properties->C/C++ General->Paths and Symbols go to the Includes tab. Add the path for C (and C++ if your header contains C++ elements).
Before you ask
- search this forum
- see the FAQ
- google
Previous Topic:File>Open doesn't
Next Topic:how to parse C file?
Current Time: Fri Mar 23 17:06:13 GMT 2018
Powered by FUDForum. Page generated in 0.01341 seconds
