Home » Modeling » UML2 Tools » How to create sequence diagram using java
How to create sequence diagram using java [message #629186] Mon, 27 September 2010 12:57 Go to next message
No real name is currently offline No real nameFriend
Hallo,
I'm a newbie to this topic and trying to create a customized sequence diagram from an input sequence diagram.
Up to now I have achieved to create lifelines in a empty diagram, but i cant figure out how to create a message that connects 2 lifelines.
I have also studied through the XML-structure of a sequence diagram and tried to find some hints that help me programming.
But if there is a docu. which describes how to create the elements in a sequence diagram? (such as messages, opt-/alt-Box, ..etc.) i would spare a lot of time.
Thanks!
Re: How to create sequence diagram using java [message #651746 is a reply to message #629186] Tue, 01 February 2011 13:24 Go to previous messageGo to next message
See Reverse Java http://www.reversejava.com. This is an excellent tool to generate UML Diagrams
Re: How to create sequence diagram using java [message #652243 is a reply to message #629186] Thu, 03 February 2011 10:27 Go to previous message
Vlad Varnica is currently offline Vlad VarnicaFriend
I found this documentation http://www.forum-omondo.com/documentation_eclipseuml_2008/re verse/reverse/reverse_engineering_example.html#6._Reverse_Me thod_and_map_this
This is a good start for understanding the sequence diagram reverse engineering concept.
Previous Topic:How to generate UML from java source
Next Topic:Invoke action Programmatically
Current Time: Sat May 26 02:41:49 GMT 2018
Powered by FUDForum. Page generated in 0.03094 seconds
