Home » Eclipse Projects » JFace » [Databinding] - List of Objects to Editable TableViewer(My editor has an editable table that connects to a list of objects inside the editors input. )
[Databinding] - List of Objects to Editable TableViewer [message #628753] Thu, 23 September 2010 23:34 Go to next message
eshvar60  is currently offline eshvar60 Friend
Member
Hey guys,
So here is the problem I've been trying to figure out for a while.
I have made an editor who takes as an input an object of type Event.
The Event class has, among other things, has a List<Parameter>.
Each Parameter object has two values: Name and Type.
I populate a TableViewer in my editor with a list of these parameters using the following code.
ObservableListContentProvider listContentProvider = new ObservableListContentProvider();
tableViewer.setContentProvider(listContentProvider);
IObservableMap[] observeMaps = PojoObservables.observeMaps(listContentProvider.getKnownElements(), Parameter.class, new String[]{"name", "type"});
tableViewer.setLabelProvider(new ObservableMapLabelProvider(observeMaps));
// Bind the parameter/attribute sheets
IObservableList eventParametersObserveList = PojoObservables.observeDetailList(model, "parameters", Parameter.class);
parameterSheet.setInput(eventParametersObserveList);
where model is an IObservableValue of type Event(this is set up by the editor framework I am using).
I then set up my cell editors for each of my columns via:
CellEditor cellEditor = new TextCellEditor(parameterSheet.getTable());
IValueProperty cellEditorProperty = BeanProperties.value("value"); IBeanValueProperty valueProperty = BeanProperties.value("name");
		parameterNameColumn.setEditingSupport(ObservableValueEditingSupport.create(parameterSheet.getTableViewer(), dataBindingContext, cellEditor, cellEditorProperty, valueProperty));
ComboBoxViewerCellEditor typeComboEditor = new ComboBoxViewerCellEditor(parameterSheet.getTable(), SWT.READ_ONLY);
typeComboEditor.setContenProvider(new ArrayContentProvider());
typeComboEditor.setLabelProvider(new LabelProvider());
typeComboEditor.setInput(getParameterTypes());
IValueProperty cellEditorProperty_1 = BeanProperties.value("value");
IBeanValueProperty valueProperty_1 = BeanProperties.value("type");
		parameterTypeColumn.setEditingSupport(ObservableValueEditingSupport.create(parameterSheet.getTableViewer(), dataBindingContext, typeComboEditor, cellEditorProperty_1, valueProperty_1));
My problem is that my model values never change. I understand that I have not bound my list properly but I do not understand how I am suppose to do that. Can anyone give me a hint please?
Thank you
Eugene
Re: [Databinding] - List of Objects to Editable TableViewer [message #629384 is a reply to message #628753] Tue, 28 September 2010 06:14 Go to previous message
Matthew Hall is currently offline Matthew HallFriend
Your cell editor property is incorrect. The cell editor property is the
property of the CellEditor object that should be observed.
See corrections inline:
What you really want to observe is TextCellEditor.control.text:
IValueProperty cellEditorProperty = CellEditorProperties.control()
.value(WidgetProperties.text(SWT.Modify));
> parameterNameColumn.setEditingSupport(ObservableValueEditing Support.create(parameterSheet.getTableViewer(),
In this case you want to observe the single viewer selection of the cell
editor's viewer property:
PojoProperties.value("viewer")
.value(ViewerProperties.singleSelection());
> parameterTypeColumn.setEditingSupport(ObservableValueEditing Support.create(parameterSheet.getTableViewer(),
> valueProperty_1));
Hope this helps,
Matthew
Previous Topic:Adding multiple instances of a same view programmaticaly and with different params
Next Topic:syntax coloring doesn't work in a multline line rule?
Current Time: Wed Feb 21 07:42:08 GMT 2018
Powered by FUDForum. Page generated in 0.02291 seconds
