Home » Modeling » UML2 » UML2 metamodel
UML2 metamodel [message #628385] Fri, 23 April 2010 11:06 Go to next message
Tforu  is currently offline Tforu Friend
Hallo!
I use mediniQVT tool(QVT Relations), where metamodel for UML2 representation is registret from this link:
http://www.eclipse.org/uml2/2.1.0/UML
for my transformations I need to know what elenets, with what dependencies is there, so there is a question -
Can I, and where, download this package (only Use Case metamodel needed) ecore or else representation???? May be at least anywhere is some pictural representation of this metamodel?
Re: UML2 metamodel [message #628386 is a reply to message #628385] Fri, 23 April 2010 12:44 Go to previous messageGo to next message
wafaa is currently offline wafaaFriend
hello
many questions exist about UML metamodel, bu let me explain 2 views and I hope to know ur against view,
1-UML metamodel is included in the UML2 plugin in ur eclipse
2- Graphical notation for this metamodel are deduced by more reading the UML specificaion have a look to it in the OMG site and at the book "Real-Time Object Uniform Design Methodology with UML.pdf" page 181 is about usecase
and about how to make mapping is by relating stereotypes with corresponding metaclass
Re: UML2 metamodel [message #628388 is a reply to message #628386] Fri, 23 April 2010 17:27 Go to previous messageGo to next message
Thank you for reply, but problem is in this UML metamodel( precize UseCase):
I want to download(ecore if possible) it or see how metamodel looks like, but in eclipse I cant find this metamodel
Any sugestions???
Re: UML2 metamodel [message #628389 is a reply to message #628388] Fri, 23 April 2010 18:50 Go to previous message
ur link doesnot work
404 File not found
hope u check it ana graphical notation exists in the book attached above as I mentioned, it is for use case ,
Previous Topic:How to : UML deep modifications
Next Topic:Re: UML2 metamodel
Current Time: Tue Feb 20 19:52:02 GMT 2018
Powered by FUDForum. Page generated in 0.01850 seconds
