Home » Modeling » UML2 » PrimitiveType problem
PrimitiveType problem [message #628345] Thu, 25 March 2010 11:11 Go to next message
Martynas  L is currently offline Martynas L
I create primitive type, and define the profile. The corresponding
EDataType's instanceName is:
v2.0.4: instanceName="java.lang.Class"
v3.0.1: instanceName="<primitive type name>"
In both versions there is the same code in
org.eclipse.uml2.uml.util.UMLUtil#convertToEcore(Profile, Map,
DiagnosticChain, Map) to set the instanceName to String:
public Object caseEDataType(EDataType eDataType) {
try {
eDataType.getInstanceClass();
} catch (Exception e) {
eDataType
.setInstanceClassName(EcorePackage.Literals.ESTRING
.getInstanceClassName());
return eDataType;
The problem is that
org.eclipse.emf.ecore.impl.EClassifierImpl#getInstanceClass( ) does throw
exception in EMF v2.2.3 (UML2 v2.0.4):
try
setInstanceClassGen(getClassForName(getInstanceClassName())) ;
catch (ClassNotFoundException e)
Class primitiveClass = getPrimitiveOrArrayClass();
if (primitiveClass != null)
setInstanceClassGen(primitiveClass);
else
throw new WrappedException(e);
But does not throw exception in EMF v2.5.0 (UML2 v3.0.1):
try
// Ignore exceptions.
That's why the instanceName is not set to String and it is not possible to
use the created primitive type as stereotype property type - a string value
can not be set as element value.
Martynas
Re: PrimitiveType problem [message #628347 is a reply to message #628345] Fri, 26 March 2010 13:55 Go to previous message
james bruck is currently offline james bruck
Hi Martynas,
Please raise a bugzilla on this.
- James.
"Martynas Lelevicius" <marte@nomagic.com> wrote in message
news:hofue9$8te$1@build.eclipse.org...
> Hello,
> try {
> eDataType
> return eDataType;
> The problem is that
> try
> else
> try
> value can not be set as element value.
> Best regards,
> Martynas
Previous Topic:PrimitiveType problem
Next Topic:UML2 sequence diagram metamodel
Current Time: Thu Jun 20 01:57:39 EDT 2013
Powered by FUDForum. Page generated in 0.01440 seconds
