Home » Modeling » UML2 » Semantics of Association and Aggregation/Composition
Semantics of Association and Aggregation/Composition [message #628279] Mon, 01 March 2010 23:09 Go to next message
amir  is currently offline amir Friend
Hi All
My question is very trivial and at the same time very technical.
Suppose, we have a system, where there are 5 Universities. Each university is composed (Composition) of 10 departments. And each department has 20 faculty members (Composition) and 10 courses (Composition). Also, we have an association of "teaching" between faculty members and courses. Now the question is, 1) Considering the type of aggregation is composition and faculty members and courses strictly belong to one and only one department, Does this mean that faculties must teach courses strictly offered by the same department or they could take courses from other departments without conceptually belonging to/ working for them? Wouldn't make sense if we had shared aggregations instead of compositions in case of the relationship between department and faculty, making it possible for one faculty to work in other departments and then taking courses offered by other departments? 2) taking the original design using compositions, Is it possible to have one faculty to take courses from other universities, without conceptually working for it? Note that this hierarchical composition could be extended. 3) how is it going to be implemented code generation-wise, considering one particular department owns instances of faculty and courses, and at the same time handling the association between their instances?
This is just an example, so don't restrict yourself to this example.
With Regards
Re: Semantics of Association and Aggregation/Composition [message #628280 is a reply to message #628279] Mon, 01 March 2010 23:22 Go to previous message
Amir,
Comments below.
amir wrote:
> Hi All
> or they could take
You mean teach?
> working for them?
Given you said teaching is an (arbitrary) association, any faculty
member could teach any course regardless of the department that contains
the faculty member or the course.
You again mention "taking courses," but you've not defined that concept.
Only the concept of teaching. The concept of "work in" has also not
been defined.
Taking and working for are not defined yet.
You're question is way too vague.
Where are you going with this line of reasoning and questioning?
> With Regards
Previous Topic:Re: Navigating on UML metamodel
Next Topic:Semantics of Association and Aggregation/Composition
Current Time: Mon May 21 07:32:46 GMT 2018
Powered by FUDForum. Page generated in 0.01881 seconds
