Home » Modeling » UML2 » Bug in UML2 specification
Bug in UML2 specification [message #628233] Sun, 14 February 2010 13:16 Go to next message
Timothy Marc is currently offline Timothy MarcFriend
Hi all,
i think i've found a bug in the UML2 specification document. Please have
a look at section 15.3.14 Transition, subsection notation (page 592), it
states that:
Re: Bug in UML2 specification [message #628234 is a reply to message #628233] Sun, 14 February 2010 13:18 Go to previous message
Sorry, again ;-)
Hi all,
states:
"However, relative to its use for signal events (see “SignalEvent (from
Communications)” on page 450) and change events
(see “ChangeEvent (from Communications)” on page 437), the
<assignment-specification> when used in transitions is
extended as follows:
<assignment-specification> ::= <attr-spec> [‘,’ <attr-spec>]*
<attr-spec> ::= <attr-name> [‘:’ <type-name>]
Note that <attr-name> is the name of an attribute to which the
corresponding parameter value of the event is assigned. If
a <type-name> is included with the attribute name, then it represents an
implicit declaration of a local attribute of that
type in the context of the effect activity to which the corresponding
parameter value of the event is assigned."
Instead of ChangeEvents what doesn't expose any assignable parameters,
it should refer to CallEvent, since a CallEvent is quite similar to
SignalEvents, shouldn't it?
Before raising an issue at the OMG, i'd like to get your opinions
concerning this.
Cheers
Timothy
Previous Topic:Bug in UML2 specification
Next Topic:Re: Associations lost when converting from UML
Current Time: Tue Apr 24 01:28:14 GMT 2018
Powered by FUDForum. Page generated in 0.01913 seconds
