Home » Modeling » UML2 » Proposed criteria for editing property subsets and element redefinitions
Proposed criteria for editing property subsets and element redefinitions [message #626584] Mon, 19 May 2008 18:31
Nicolas Rouquette is currently offline Nicolas RouquetteFriend
With org.eclipse.emf.edit.ui.celleditor.FeatureEditorDialog, the UML
Editor could have user-friendly support for editing property subsets and
element redefinitions where applicable.
To be effective, this would need reasonable queries to identify
all of the possible elements that could be subsetted or redefined
respectively.
What do you think of the following criteria for selecting property subsets?
context uml::Property : Bag(uml::Property)
body:
let cls:Bag(uml::Classifier)=self.featuringClassifier
.oclAsType(uml::Classifier) in
let parents:Bag(uml::Classifier)=cls->union(cls.allParents()) in
let prop:Bag(uml::Feature)=cls.allFeatures()
->intersection(parents.ownedMember->select(oclIsKindOf(uml::Feature))
->collect(oclAsType(uml::Feature)))->excluding(self)
->select(oclIsKindOf(uml::Property)) in
prop->select(let p:uml::Property=oclAsType(uml::Property) in
self.type.conformsTo(p.type))
What do you think of the following criteria for selecting element
redefinitions?
context uml::RedefinableElement : Bag(uml::RedefinableElement)
body:
if self.oclIsKindOf(uml::Property) then
let redefProp:Bag(uml::Feature)=parents.allFeatures()
->select(f|
f.oclIsKindOf(uml::Property) and
self.type.conformsTo(f.oclAsType(uml::Property).type))->asBag()
->collect(oclAsType(uml::Property))
->excluding(self.oclAsType(uml::Property))
->asBag())
in redefProp
else
if self.oclIsKindOf(uml::Operation) then
let redefOp:Bag(uml::Feature)=parents.allFeatures()
->select(o|
o.oclIsKindOf(uml::Operation) and
self.type.conformsTo(o.oclAsType(uml::Operation).type))->asBag()
->select(oclIsKindOf(uml::Operation))
->collect(oclAsType(uml::Operation)
->excluding(self.oclAsType(uml::Operation))
->asBag())
in redefOp
else
Set{}
endif
endif
-- Nicolas.
Previous Topic:Re: Programmatically moving Packages within an UML model
Next Topic:Re: Programmatically moving Packages within an UML model
Current Time: Fri May 25 07:24:27 GMT 2018
Powered by FUDForum. Page generated in 0.01607 seconds
