Home » Eclipse Projects » Remote Application Platform (RAP) » UISynchronizer and use32Threading
UISynchronizer and use32Threading [message #625889] Wed, 22 September 2010 10:47 Go to next message
Yury Mising name is currently offline Yury Mising nameFriend
Member
Hi, All!
I've got the situation that is described in https://bugs.eclipse.org/bugs/show_bug.cgi?id=219913 : have to open Logon dialog when Workbench is still starting. This leads to deadlock, because the Logon dialog is opened in Dispaly.syncExec.
Therefore I have a question: should we define the constant UISynchronizer.use32Threading = true in RAP and use 3.2 threading to done all syncExecs properly while Workbench is starting? If not, I have to search the cause of my problem somewhere else Sad
Yury.
Re: UISynchronizer and use32Threading [message #627181 is a reply to message #625889] Wed, 22 September 2010 22:01 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf SternbergFriend
Hi Yury,
even if it would solve this problem, switching to 3.2 threading would be
a hack and we'd need very good reasons to do so.
Do you think the solution to bug 182176 could help you? I think we could
easily provide the class DisplayAccess now.
Regards, Ralf
Ralf Sternberg
Need professional support for RAP and RCP?
http://www.eclipsesource.com/support/
Twitter: http://twitter.com/eclipsesource
Blog: http://www.eclipsesource.com/blogs/
Re: UISynchronizer and use32Threading [message #627567 is a reply to message #627181] Thu, 23 September 2010 02:26 Go to previous messageGo to next message
Member
Hi, Ralf!
Yes, I think fixes of the bug 182176 can resolve my problem.
New API "org.eclipse.ui.application.DisplayAccess" has been
created. This class has one static method, "accessDisplayDuringStartup()".
Calling this method on any thread not created by the UI (ie: any user Thread)
will allow that thread to access the Display.async() and Display.sync() methods
as if they were one of our privileged startup threads.
That's exactly what I need.
Yury.
Re: UISynchronizer and use32Threading [message #628488 is a reply to message #627567] Thu, 23 September 2010 12:52 Go to previous messageGo to next message
Hi Yury,
I added a note to bug 309661 to open this API during the workbench
migration. You may set yourself on copy for this bug if you like.
Regards, Ralf
Ralf Sternberg
Re: UISynchronizer and use32Threading [message #628763 is a reply to message #628488] Fri, 24 September 2010 04:39 Go to previous message
Member
Thanks for response, Ralf!
Yury.
Previous Topic:Support for RTL (BIDI) Languages in RAP
Next Topic:Animations
Current Time: Mon Jun 25 20:06:31 GMT 2018
Powered by FUDForum. Page generated in 0.02140 seconds
