Re: Using collaboration [message #624622 is a reply to message #624453] |
Mon, 15 December 2008 07:05 |
Originally posted by: remy.suen.gmail.com
Heinz Drews wrote:
> - I don't have "Communications" in the context menus in Navigator or
> Package Explorer
> Is there any additional setup required?
I can only vaguely recall this context menu. What exactly are you
attempting to test / try out?
> - Trying to use the ecftcp://ecf.eclipse.org:3282/server I get
> "connection refused?
I think this has been down for some time.
For my personal testing purposes, I usually just run the
org.eclipse.ecf.server.generic.app.ServerApplication class located in
the org.eclipse.ecf.server.generic bundle. But I have the code in my
workspace so this is easy for me to do.
> - Setup of a local ECF server
> I tried to setup an own ECF server following the wiki
> http://wiki.eclipse.org/ECF_Servers
> I have created a Equinox directory by installing the launcher and the
> ECF SDK. After some adjustments to the start procedure I get Equinox
> up. But the wiki mentions then to use "startApp" to launch the ECF
> server which fails.
What do you exactly mean when you say "which fails"? Are there error
messages or something?
Remy
Re: Using collaboration [message #624624 is a reply to message #624623] |
Mon, 15 December 2008 07:32 |
Heinz Drews wrote:
> "startApp" is not accepted as command, just the help text is shown.
And what about the -application method?
Remy
Re: Using collaboration [message #624626 is a reply to message #624625] |
Mon, 15 December 2008 07:59 |
Heinz Drews wrote:
> The registration works but I still can't share a project.
I only remember this menu item from a long time ago. Where are you
reading this? What do you hope to achieve by "sharing a project"?
Remy
Re: Using collaboration [message #624628 is a reply to message #624627] |
Mon, 15 December 2008 09:41 |
> I have followed the wiki entry assuming that this is necessary to get a
> shared editor working.
Right. This is why I was interested in where you were reading this (so
it can be amended/updated/whatever accordingly). Please provide a link
to the wiki page in question.
You might want to try this link for getting shared editing to work.
http://wiki.eclipse.org/DocShare_Plugin
Remy
FUDForum. Page generated in 0.25376 seconds
