Home » Eclipse Projects » Platform - User Assistance (UA) » Infocenter locales and nl init-param in web.xml
Infocenter locales and nl init-param in web.xml [message #623840] Fri, 08 January 2010 15:11
Gerardo Laster is currently offline Gerardo LasterFriend
I've been checking the information at platform.doc.isv/guide/ua_help_setup_infocenter.htm
The above instructions work well for a local infocenter, but I can't make them work on Tomcat.
I am trying to add the nl and locale init-param to the Tomcat web.xml file.
So far, I haven't been able to make it work using
<init-param><param-name>-nl</param-name><param-value>de </param-value></init-param>
<init-param><param-name>nl</param-name><param-value>de</param-value ></init-param>
1. Any idea which one is the correct one?
Also, I have 2 web.xml, one in the build under C:\tomcat\webapps\proddocs\WEB-INF
and the other inside the webapps under web-archive/help/WEB-INF/web.xml
2. Which one is Eclipse actually using?
Thanks in advance,
Previous Topic:Using Eclipse Help System with Maven for a SWT Standalone Application
Next Topic:Re: Infocenter indexing hangs
Current Time: Thu Mar 22 21:15:12 GMT 2018
Powered by FUDForum. Page generated in 0.01578 seconds
