Home » Eclipse Projects » Platform - User Assistance (UA) » Re: Is there any way filter some primary help tocs?
Re: Is there any way filter some primary help tocs? [message #623346] Sat, 02 May 2009 11:51
Ben Vitale is currently offline Ben Vitale
I don't think you can provide an action that will open the Help system
with only certain TOCs showing, but I could be mistaken.
You could certainly provide an action that opens a specific help page
(such as your top level help document). But the other TOCs will still
be showing. Check out HelpContentsAction and IWorkbenchHelpSystem for
starting points.
Ben
Jiyul wrote:
> Thanks for reply.
> Our product is deployed as plugin, So I don't want to filter other tocs
> all the times. I just want we can let our user can see only our TOC
> contents when they selected specific menu.
> Ben Vitale wrote:
>> You can filter out undesirable TOCs using the HELP_DATA file. Does
>> that help you at all?
>> http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/ua_help_setup_preferences.htm
>> Otherwise please elaborate further on your scenario.
>> Regards,
>> Ben
>> Jiyul wrote:
>>> I needs to show just only our help contents by some menu. And I want
>>> to use eclipse information system. but show help command does not
>>> have a parameter to do it.
>>> any idea?
Previous Topic:Re: Is there any way filter some primary help tocs?
Next Topic:A handler conflict occurred. This may disable some commands.
Current Time: Sat May 18 22:39:11 EDT 2013
Powered by FUDForum. Page generated in 0.01524 seconds
