Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [TEXO] Problem with ClassCastException in ModelPackage
[TEXO] Problem with ClassCastException in ModelPackage [message #623210] Wed, 15 September 2010 23:01 Go to next message
Mark Hoffmann is currently offline Mark HoffmannFriend
I created a code-gen.annotationsmodel from my ecore to change the package path.
The enums will not saved in the correct folder from the annotionsmodel, but the package definition in the generated code ist correct.
In my model if have a Contact class and an enum called ContactType. If I call ModelPackage.INSTANCE I get the following exception:
Caused by: java.lang.ClassCastException: org.eclipse.emf.ecore.impl.EEnumImpl cannot be cast to org.eclipse.emf.ecore.EClass
at de.sim.texo.model.common.person.PersonModelPackage.getContac tEClass(PersonModelPackage.java:787)
at de.sim.texo.model.common.person.PersonModelPackage.initializ e(PersonModelPackage.java:405)
at de.sim.texo.model.common.person.PersonModelPackage.<clinit>(PersonModelPackage.java:376)
... 31 more
The generated code looks like this:
* Returns the {@link EClass} '<em><b>Contact</b></em>'.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @return an instance of the {@link EClass} '<em><b>Contact</b></em>'
* @generated
public EClass getContactEClass() {
return (EClass) getEPackage().getEClassifiers().get(
CONTACT_CLASSIFIER_ID);
I debugged a little bit. This method return the ContactType instead of the Contact.
In my ecore looks like this:
<eClassifiers xsi:type="ecore:EClass" name="Contact">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="type" lowerBound="1" eType="#//ContactType"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="context" lowerBound="1"
eType="#//ContactContextType" defaultValueLiteral="PRIVATE"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value" lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="id" lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//ELong"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="note" eType="ecore:EClass common.ecore#//Note"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="ContactType">
<eLiterals name="EMAIL"/>
<eLiterals name="PHONE" value="1"/>
<eLiterals name="MOBILE" value="2"/>
<eLiterals name="FAX" value="3"/>
<eLiterals name="WWW" value="4"/>
<eLiterals name="MESSENGER" value="5"/>
<eLiterals name="OTHER" value="6"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="ContactContextType">
<eLiterals name="PRIVATE"/>
<eLiterals name="BUSINESS" value="1"/>
<eLiterals name="OTHER" value="2"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ContactList">
<eStructuralFeatures xsi:type="ecore:EReference" name="contacts" upperBound="-1"
eType="#//Contact"/>
</eClassifiers>
Does anybody know this problem?
Mark
Re: [TEXO] Problem with ClassCastException in ModelPackage [message #623214 is a reply to message #623210] Thu, 16 September 2010 06:52 Go to previous message
Martin Taal is currently offline Martin TaalFriend
Hi Mark,
Maybe the CONTACT_CLASSIFIER_ID has a wrong value, i.e. the same value as the classifier id of the enum (can you check
this in the generated ModelPackage class?)?
Can you send me the complete ecore and the annotations model? Then I can try to reproduce the problem.
Btw, what do you mean with this:
ist correct.
The enum classes were not generated you mean?
gr. Martin
> lowerBound="1"
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> upperBound="-1"
> </eClassifiers>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Previous Topic:[MINT] Coloring of Java-Files in Project Explorer
Next Topic:[EEF] Ant task to generate models and code
Current Time: Wed Jan 17 22:21:15 GMT 2018
Powered by FUDForum. Page generated in 0.01854 seconds
