Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Do bounds (lower and upper) of EReference have any effect?
Do bounds (lower and upper) of EReference have any effect? [message #623136] Thu, 12 August 2010 10:58 Go to next message
Oleg Bolshakov is currently offline Oleg BolshakovFriend
Member
There two classes (Class1 and Class2) and EReferences between them in EMF model (,ecore file). EReferences multyplicity's are 0..* for src role and 0..3 for dst role. I can see two ELists created for each class but I can add any count of objects to any of the lists. The question is - is there a realisation of EReference's bounds (for example upper bound) and why doesn't it have any effect in my Java code?
Here is the code:
Package1.impl.Package1FactoryImpl.init();
Package1.meta.Package1Factory factory = Package1.meta.Package1Factory.eINSTANCE;
Class1 object1 = factory.createClass1();
object1.setName1("object1");
Class2 object2 = factory.createClass2();
object2.setName2("object2");
EList<Class1> dests = object2.getDst();
dests.add(object1);
dests.add(object7);
dests.add(object8);
dests.add(object9);
dests.add(object10);
dests.add(object11);
dests.add(object12);
Re: Do bounds (lower and upper) of EReference have any effect? [message #623139 is a reply to message #623136] Thu, 12 August 2010 16:25 Go to previous message
Ed Willink is currently offline Ed WillinkFriend
Hi Rrock
The bounds are used when you validate(). In practice performing
too-fine-grained validation is awkward. For instance changing an element
in an exactly two-off list is not possible using just the add/remove
list protocol.
If you use EMF Validation's live validation, they are checked more often.
Ed Willink
> Here is the code:
> dests.add(object1);
> dests.add(object7);
> dests.add(object8);
> dests.add(object9);
Previous Topic:Do bounds (lower and upper) of EReference have any effect?
Next Topic:Emfatic download
Current Time: Thu Apr 19 10:13:43 GMT 2018
Powered by FUDForum. Page generated in 0.02468 seconds
