Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Re: XText: cant find main class org.eclipse.emf.mwe.core.WorkflowRunner
Re: XText: cant find main class org.eclipse.emf.mwe.core.WorkflowRunner [message #622276] Fri, 05 March 2010 15:31 Go to next message
HansBj is currently offline HansBjFriend
I just tried again to create a XText Project using the wizard.
It does not include any libraries at all!
The first error I get is that the reference in the grammar file to
org.eclipse.xtext.common.Terminals
cannot be solved.
regards, HB.
Re: XText: cant find main class org.eclipse.emf.mwe.core.WorkflowRunner [message #622277 is a reply to message #622276] Fri, 05 March 2010 16:34 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Am 05.03.10 16:31, schrieb HansBj:
> cannot be solved.
> regards, HB.
Hi Hans Björn,
I just removed the dust from an old windows box, downloaded the Xtext
distro and launched Eclipse and created an empty workspace in c:/eclipse/ws.
After choosing
New -> Project .. -> Xtext Project
I end up with 3 projects in my workspace. They define the required deps,
e.g. the runtime project (org.xtext.example.mydsl by default) contains a
manifest.mf with the following entries:
Require-Bundle: org.eclipse.xtext,
org.eclipse.xtext.generator;resolution:=optional,
de.itemis.xtext.antlr;resolution:=optional,
org.apache.commons.logging;resolution:=optional,
org.eclipse.emf.codegen.ecore;resolution:=optional,
org.eclipse.xtext.log4j;resolution:=optional,
org.eclipse.emf.mwe.utils;resolution:=optional,
org.eclipse.emf.mwe.core;resolution:=optional,
com.ibm.icu;resolution:=optional,
org.eclipse.xtext.xtend;resolution:=optional
Can you confirm this behaviour on your machine?
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Re: XText: cant find main class org.eclipse.emf.mwe.core.WorkflowRunner [message #622278 is a reply to message #622277] Fri, 05 March 2010 16:42 Go to previous messageGo to next message
yes, the same happens on my machine.
But there is no "Referenced Libraries" in the workspace / package view.
regards, HB.
Re: XText: cant find main class org.eclipse.emf.mwe.core.WorkflowRunner [message #622279 is a reply to message #622278] Fri, 05 March 2010 18:38 Go to previous message
Hi Hans Björn,
the referenced libraries are displayed as plugin dependencies and
therefore they show the resolved deps from the manifest. The compile
path is derived from this information.
As far as I can tell, the three projects work like a charm but I'll
double check on Mondays.
Sebastian
Am 05.03.10 17:42, schrieb HansBj:
> regards, HB.
Previous Topic:Suppress attributes for EMF Compare?
Next Topic:xpand2::Type
Current Time: Mon May 21 15:22:13 GMT 2018
Powered by FUDForum. Page generated in 0.01867 seconds
