Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » clause "implements" for a EMF generated class
clause "implements" for a EMF generated class [message #622053] Wed, 27 January 2010 11:25
Carlos  is currently offline Carlos
Member
Hi.
I want to declare a clause "implements" for a class which is regenerated using EMF ecore.
If I change the tag @generated adding NOT, to get the "implements" untouched, the code of the class will not be generated...
But if I leave the tag @generated without NOT, when the code was generated, "implements" will be deleted.
So, have you got any suggestion about this issue?
Thanks in advance,
Carlos.
Previous Topic:EMF Compare Editor: How to add text compare tab?
Next Topic:Ecoretools sources not included in the SDK
Current Time: Tue Oct 08 07:46:07 EDT 2013
Powered by FUDForum. Page generated in 0.01561 seconds
