Home » Modeling » UML2 » Which packages in UML2 superstructure does Eclipse UML2 implement?
Which packages in UML2 superstructure does Eclipse UML2 implement? [message #619764] Wed, 06 June 2007 19:28
Sunfire is currently offline SunfireFriend
Member
Earlier I focused on only a subset of the UML2 superstructure and assumed
that the class names are unique. However, when I tried to match an
instance of the UML2.0 implementation with a class in the metamodel by
class name, I found there were many matches. For example, if I create an
object of type org.eclipse.uml2.Class, then there are at least two classes
in the metamodel matching the object's type name: one is the Class in the
Kernel namespace and the other is the Class in the Communications package.
So my question is:
What packages in UML2.0 (05-07-04) does the UML2_1.1.1 implement? That is,
given a specific class in org.eclipse.uml2, how do I know which meta class
in does this class correspond to? Although some of them are pretty
obvious, many of them are not due to unfamiliarity.
Thank you for any help,
-- Sunny
Previous Topic:Re: proxy resolution problem
Next Topic:TOPCASED and tagged values?
Current Time: Sat Feb 24 10:31:45 GMT 2018
Powered by FUDForum. Page generated in 0.01501 seconds
