Home » Eclipse Projects » Dali » Eclipse JPA project - defining connection to Oracle RAC
Eclipse JPA project - defining connection to Oracle RAC [message #617696] Wed, 13 January 2010 19:43 Go to next message
No real name is currently offline No real nameFriend
Recently I wanted to play a bit with Eclipse and JPA. Thus I wanted to create a JPA project.
I got stuck when specifying the database connection, as editing the "Connection URL" (shown on the image) is not possible and I want to enter a (good, working) connection string to an Oracle RAC server which looks more or less like that:
jdbc:oracle:thin:@(DESCRIPTION=(ADDRESS= (PROTOCOL=TCP) (HOST=...
Am I doing something obviously wrong? Or is it currently a "feature" of the Data Source Explorer?
MH
Re: Eclipse JPA project - defining connection to Oracle RAC [message #618687 is a reply to message #617696] Fri, 15 January 2010 20:37 Go to previous message
Neil Hauge is currently offline Neil HaugeFriend
In this case the wizard is trying to help the user by providing form entry of these values as opposed to typing in the string. I would agree that it would also be nice to be able to paste in the string you want to use. Generally speaking it wouldn't be a problem to use the form to achieve the URL you want to use, but if it really is a problem you can simply create a "Generic JDBC" connection profile. This will allow you to input any connection URL that you want, without any form to get in the way. It does require an extra bit of configuration, but it's pretty minimal.
Hope this helps,
Neil
Previous Topic:Run JPA Project without Server
Next Topic:Re: Eclipse JPA project - defining connection to Oracle RAC
Current Time: Mon Feb 26 03:51:57 GMT 2018
Powered by FUDForum. Page generated in 0.03207 seconds
