Home » Archived » Service Oriented Architecture Tools Platform (STP) » EID Error invoking "New" Wizard
EID Error invoking "New" Wizard [message #616681] Sat, 28 June 2008 08:33 Go to next message
Ron Gavlin is currently offline Ron GavlinFriend
Member
The following error is generated in the console when I execute the "New"
EIP wizard using the new Ganymede release. Any ideas?
!ENTRY org.eclipse.jface 4 2 2008-06-28 04:17:09.517
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: 0
org.eclipse.stp.eid.datamodel.diagram.part.MyCimeroEditorCre ationWizardPage.createControl(MyCimeroEditorCreationWizardPa ge.java:115)
org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1147)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1139)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.jav a:1128)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1126)
org.eclipse.ui.internal.dialogs.NewWizardSelectionPage.advan ceToNextPageOrFinish(NewWizardSelectionPage.java:71)
org.eclipse.ui.internal.dialogs.NewWizardNewPage$1.doubleCli ck(NewWizardNewPage.java:355)
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:799)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:797)
org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1419)
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1173)
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:237)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:234)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:295)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
org.eclipse.ui.internal.handlers.WizardHandler$New.executeHa ndler(WizardHandler.java:253)
org.eclipse.ui.internal.handlers.WizardHandler.execute(Wizar dHandler.java:273)
org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:281)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:247)
org.eclipse.ui.internal.actions.CommandAction.runWithEvent(C ommandAction.java:157)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
Re: EID Error invoking "New" Wizard [message #616683 is a reply to message #616681] Tue, 01 July 2008 09:49 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
Please file a bug, and reply here with the bug number for tracking purposes.
Thanks!
Antoine
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: EID Error invoking "New" Wizard [message #616687 is a reply to message #616683] Tue, 08 July 2008 20:58 Go to previous messageGo to next message
Adam is currently offline AdamFriend
I ran into the same problem.
I submitted a bug:
Bug 240077.
Re: EID Error invoking "New" Wizard [message #616688 is a reply to message #616681] Tue, 22 July 2008 10:13 Go to previous message
Originally posted by: lichen782.yahoo.com.cn
I had the same problem and it seems almost one month has passed...Is there
any way figure out?
Previous Topic:Eclipse Ganymede STP xmlvalidator doesn't work
Next Topic:SCA Tools creation review has been successful!
Current Time: Sun May 27 23:45:44 GMT 2018
Powered by FUDForum. Page generated in 0.01831 seconds
