Home » Eclipse Projects » JavaServer Faces » Re: JSF app no longer deploys class files
Re: JSF app no longer deploys class files [message #616497] Mon, 04 February 2008 17:03
Eric Rizzo is currently offline Eric RizzoFriend
David Karr wrote:
> I have no idea how it got into this state, but after recreating the
> application from scratch (just copying the source files over after
> creating the skeleton), I see the differences in the metadata files that
> make the difference. In the
> ".settings/org.eclipse.wst.common.component" file, I needed to have the
> following line:
> <wb-resource deploy-path="/WEB-INF/classes" source-path="/src"/>
> If this happens again, if it's less practical to recreate the project,
> at least I might be able to fix it by adding this line.
> I would think it would be a good idea to document the schemas for these
> metadata files. I couldn't find any documentation on this file, or
> others like it. I'm sure I just didn't know where to look.
Those files are probably not documented; they're not intended for user
modification as they are internal "state" of the WST tools.
Eric
Previous Topic:Re: JSF app no longer deploys class files
Next Topic:How to attach source of JSF implementation?
Current Time: Mon May 28 03:07:41 GMT 2018
Powered by FUDForum. Page generated in 0.01953 seconds
