Home » Archived » GMT (Generative Modeling Technologies) » [Epsilon] running the ETL sample from Java
[Epsilon] running the ETL sample from Java [message #609669] Mon, 26 November 2007 18:45
Jose Alfredo Serrano is currently offline Jose Alfredo SerranoFriend
I'm new on Epsilon and I was trying to play with the examples.
In the ETL part, there is an example of using ETL from java. I have
modified the given Java class ETLStandaloneExample to make it compile
with the latest versions:
-EtlModuleImple becomes EtlModule,
-The method shutdown has been renamed as disposed
-the 'module.setSourceModel()' modified into
module.getContext().getTransformationStrategy().setSourceMod el()
-the 'module.setTargetModel()' modified into
module.getContext().getTransformationStrategy().setTargetMod el().
Is this alright?
Well, It says that DB!Database not found. Actually I have a plugin that
I ran as java application for this sample. The models (OO and DB) and
the instances (DBInstance and OOInstance) are placed at the project
folder. Am I missing something? Maybe the problem comes from the
modifications I made to make the class to compile.
Has anybody run this example successfully?
Previous Topic:[TCS]:Error with TCS Wizard
Next Topic:Re: [MOFScript] Unprotected regions
Current Time: Thu Apr 19 19:56:29 GMT 2018
Powered by FUDForum. Page generated in 0.01341 seconds
