Home » Eclipse Projects » Plugin Development Environment (PDE) » Prevent archiving rcp application in headless build
Prevent archiving rcp application in headless build [message #603969] Tue, 05 January 2010 19:37 Go to next message
VincentL is currently offline VincentLFriend
Member
1) Is is possible to prevent the default headless build of PDE
(org.eclipse.pde.build_...\scripts\productBuild\productBuild .xml) of creating an archive
file at the end of the build process of my rcp application. Is there a property for that?
Or should I override the default assemble process?
What I would like to do instead, is to copy all files that the archive must contain to a
temporary directory. Our application already provide an installation software that will
grab these files and make the installer...
2) How could I customize part of my build process without changing the default PDE build
process?
Note that I'm using PDE to make an headless build of my RCP application as in the following:
java -jar c:\eclipse\plugins\org.eclipse.equinox.launcher_XXX.jar -application
org.eclipse.ant.core.antRunner -buildfile productBuild.xml -D... -D...
Thanks all,
Vincent
Re: Prevent archiving rcp application in headless build [message #982879 is a reply to message #603969] Tue, 13 November 2012 13:48 Go to previous messageGo to next message
Danny Schimke is currently offline Danny SchimkeFriend
Hi!
Thats interesting. I have to do something similar. Is there any solution?
Thanks!
-Danny Schimke
Re: Prevent archiving rcp application in headless build [message #986598 is a reply to message #982879] Wed, 21 November 2012 06:59 Go to previous message
Sabir pasha is currently offline Sabir pashaFriend
Member
Hi Vincent , Danny
There is definetely a way for that i believe.
You can try overwriting ant calls in customTargets.xml , allElements.xml , productBuild.xml and such files
These files are present in the 'eclipse\plugins\org.eclipse.pde.build_3.6.0.v20100603\templates\headless-build' directory in eclipse
Hope that helps.
Previous Topic:Newbie, Eclipse Plugin For ActionScript Developers
Next Topic:Help Generating Javadoc For Eclipse API Restriction Tags
Current Time: Fri Feb 23 19:11:38 GMT 2018
Powered by FUDForum. Page generated in 0.02127 seconds
